rko4all
Problem assigning an IP address to a VM in VMware Esxi 6.7
Wed Oct 05, 2022 1:56 am
Hello There ,
I'm very new to Mikrotik and recently I have purchased a dedicated server and I'm trying to run a VM with RouterOS .
The issue I'm facing is that when assigning an IP address to Mikrotik , I can't ping 8.8.8.8 and I get no routes to host .
Here is what the data center has provided me :
IP address I'm trying to set on Mikrotik : 185.X.X.65
Gateway : 172.27.7.229
Netmask : 255.255.255.252
Here are the commands I entered to get the job done :
ip address add address=185.X.X.65 netmask=255.255.255.252 network=172.27.7.229 interface=ether1
and :
ip route add gateway=172.27.7.229
after running those 2 commands , when I ping 8.8.8.8 , I get no routes to host message . Seems I don't have internet access .
Can you please help me get it working ?
Regards ,
Sob
Re: Problem assigning an IP address to a VM in VMware Esxi 6.7  [SOLVED]
Wed Oct 05, 2022 2:42 am
No, something is clearly wrong, what you say you got from data center doesn't make sense.
If you're supposed to have 185.X.X.65 with mask 255.255.255.252 (/30), then only other available address in that subnet is 185.x.x.66 and that could be gateway. But if gateway is really 172.27.7.229, then it would have to be point to point config, which would have /32 mask:
add address=185.X.X.65/32 network=172.27.7.229 interface=ether1
rko4all
Wed Oct 05, 2022 6:30 pm
Thank you for the response . As soon as I removed netmask from my IP assigning command , it worked !
Sob
Wed Oct 05, 2022 7:57 pm
You may still want to ask your hosting for clarification. I assume they had some reason for giving you that mask.
Users browsing this forum: No registered users and 0 guests
