ilm
MQTT Subscribe feature
Tue Oct 18, 2022 1:00 am
Use case:
I'm using a CRS112-8P-4S-IN as PoE Switch for a video surveillance system in a private house. Some cameras are indoor and should only be active, when nobody is home.
I want to make sure that the cameras are turned off. For that I wrote a python script, that turns off the PoE using the RouterOS REST API. It is working fine.
But
By using the REST API I have to store credentials with write permissions together with the script. If my server is compromised my switch is collateral damage.
I could write a schedule on the switch and execute it every 5 seconds to check an external HTTP server. But that is just ugly.
Very nice would be the ability of the IoT/MQTT feature to provide a subscribe option to execute a script on a certain topic.
That would also allow me, to play the Mario theme every time someone enters the server room.
rextended
Re: MQTT Subscribe feature
Tue Oct 18, 2022 1:11 am
With a little more imagination, have the PoE ports shut down when your mobile is registered to Wi-Fi.
The pseoducasual MAC address is not a problem, for the same network, it always remains the same.
Hominidae
Tue Oct 18, 2022 9:39 am
Use case:
...next best hack, if this switch is soley used for this set of cameras: use a smart plug, i.e. with tasmota firmware and a local rule to switch its power supply completely.
Users browsing this forum: No registered users and 1 guest
