wongdi
How to restore to factory firmware
Tue Oct 18, 2022 3:54 pm
Recently I need a very old version of the firmware for a network experiment, but my attempt to download the old firmware failed, I would like to ask if there is any other way to factory reset the firmware. CRS305
erlinden
Re: How to restore to factory firmware
Tue Oct 18, 2022 3:57 pm
It would require the software, what version are you looking for?
wongdi
Tue Oct 18, 2022 5:48 pm
If there is no way to restore the factory firmware, I would like to get a SWOS 2.8 or earlieri😊
erlinden
Tue Oct 18, 2022 5:55 pm
Sorry, wasn't aware that this device is running SWoS.
Can't you manually change the URL to a previous version? Any reason on why you want (or have) to downgrade?
wongdi
Wed Oct 19, 2022 2:52 pm
Manual downloads are only possible up to version 2.10, older versions are not available. I had a little experiment that might need a version old enough to take advantage of his bug.😂
semaja2
Wed Oct 19, 2022 3:43 pm
Is it possible to load the "backup" firmware which is the one the device came with?
https://wiki.mikrotik.com/wiki/SwOS/CRS ... _Reinstall
It is possible to load a SwOS backup firmware in case standard firmware breaks or upgrade fails:
Connect to the device using a serial console
Boot SwOS
Choose "p - boot primary SwOS"
After loading backup firmware, it is possible to connect to 192.168.88.1 using a web browser and install new SwOS firmware.
wongdi
Wed Oct 19, 2022 3:58 pm
Boot SwOS
Thanks for the suggestion, I'll try it tomorrow, I'm not sure if he has a previous version of the firmware present.😁
rextended
Wed Oct 19, 2022 7:17 pm
NO. This feature is not available at all, on any MikroTik device.
rextended
Wed Oct 19, 2022 7:49 pm
On previous version the file is called swos-crs3051g4s-2.8.bin but is for internal use only.
For install previous 2.8, boot on RouterOS, downgrade to version that contain 2.8 (6.42.10), upgrade from RouterOS the SwOS (2.8p), then reboot on SwOS mode.
wongdi
Fri Oct 21, 2022 5:03 pm
I may not understand your explanation very well. I don't think downgrading the routeros firmware will get an earlier version of SwOS because I tried overnight without success.🤣
Users browsing this forum: No registered users and 2 guests
