sgiglio
CHR ipsec memory leak
Wed Nov 02, 2022 1:12 pm
Hello, I have a problem on my CHR v.6.47.10.
Specifically, after the establishment of an ipsec session a certain amount of memory is used, but if the ipsec session fails or if it is ceased, the memory is not freed.
To recover the memory, you need to reboot. What could be the cause ? Has anyone happened to?
Thanks in advance
pe1chl
Re: CHR ipsec memory leak
Wed Nov 02, 2022 1:23 pm
I do not recognize that, but as always it is best to first upgrade to the newest version (6.49.7) before discussing bugs.
sgiglio
Wed Nov 02, 2022 1:48 pm
unfortunately, this problem also occurs with version 7 and with the ARM platform.
On the other hand, on versions 6.44 installed, it does not happen.
pe1chl
Wed Nov 02, 2022 2:11 pm
I did not say version 7, but rather the latest v6 version 6.49.7
Did you test that?
sgiglio
Thu Aug 24, 2023 11:07 am
after some time I finally managed to try the 6.49.7 version.
I notice similar behavior. Memory tends to rise every day until it becomes saturated.
I have a CHR 6.49.7 machine with 2Gb of Ram and 80 ipsec.
Is there any parameter to configure to avoid this anomalous behavior?
I attach a screen of the memory trend after the restart and after 1 day. You see a steady increase. This happens until the memory is full
Thx
pe1chl
Thu Aug 24, 2023 12:10 pm
Probably yes, because I run a CHR with 6.49.7 that has several IPsec sessions and has been up for 91 days now, and it does not show this behavior.
(memory usage is increasing a little over time, but by far not as steeply as you are showing)
Users browsing this forum: Amazon [Bot] and 1 guest
