ColinSlater
Automatic Config Backup --> Not working in December
Fri Dec 02, 2022 11:01 am
Good Morning Mikrotik Community,
I found a script on a forum post here somewhere for doing automatic backup of the config. I adapted it a bit to do what I wanted it to do, and it's been working fine throughout November, creating a backup file every day.
Seems to have stopped working now that we're in December though, and I have no clue why - this is only the second script that I've ever worked with...
:local theDate [/system clock get date]
:local theDay [ :pick $theDate 4 6 ]
:local theMonth [ :pick $theDate 1 3 ]
:local theMonthNumber ([:find "xxanebarprayunulugepctovecANEBARPRAYUNULUGEPCTOVEC" "ov" -1] / 2);
:if ($theMonthNumber>12) do={:set theMonthNumber ($theMonthNumber - 12)}
:if ($theMonthNumber < 10) do={:set theMonthNumber "0$theMonthNumber"}
:local theYear [ :pick $theDate 7 11 ]
:local exportFileName "$theYear-$theMonthNumber-$theDay_RB4011.rsc"
export terse show-sensitive file="$exportFileName"
It should produce a file like "2022-12-01_RB4011.rsc", obviously changing the date each day.
Any thoughts?
Thanks very much.
matiss
Re: Automatic Config Backup --> Not working in December
Fri Dec 02, 2022 11:40 am
Replace "ov" with $theMonth
ColinSlater
Fri Dec 02, 2022 3:40 pm
Thanks very much :)
That's fixed it!
rextended
Sat Dec 03, 2022 1:43 pm
Try to not blindly copy&paste scripts
The script here
viewtopic.php?p=968074#p968074
:local M ([:find "xxanebarprayunulugepctovecANEBARPRAYUNULUGEPCTOVEC" "ov" -1] / 2); :if ($M>12) do={:set M ($M - 12)}
:put $M
is obviously one example for november,
ColinSlater
Tue Aug 29, 2023 2:33 am
Hi Everyone,
Noticed some strange behaviour that seems to have been happening for a while.
My backup script, which has been happily running for months, suddenly stopped generating the filenames as expected.
Instead of getting something like 2023-08-29_RB4011.rsc (obviously, the date part is dynamic, as per the script here), I'm getting something like this:
-29-0--0_RB4011.rsc
Anyone got any thoughts?
We've not changed the script, but since implementing the script last year, we have updated the ROS a few times - currently running ROS 7.10.
Colin
diamuxin
Tue Aug 29, 2023 9:42 am
share your backup script so they can help you...
rextended
Tue Aug 29, 2023 12:03 pm
Yep, you clearly don't read the release notes at all and update the system without even a clue what you're doing.
From RouterOS 7.10 the dates are FINALLY reported in the right and more logical ISO:8601 yyyy-MM-dd format instead of the <censored> Mmm/dd/yyyy
Now, if the script is the same of the OP, can you replace all on RouterOS 7.10+ with simply:
revised untested code
/export terse show-sensitive file="$[/sys clock get date]_RB4011.rsc"
ColinSlater
Sat Sep 02, 2023 12:57 am
Thanks for the kind words in your reply.
I’ll update my script.
Users browsing this forum: No registered users and 7 guests
