lebowski
Cisco CPU probe fix
Thu Dec 08, 2022 1:00 am
I found the Cisco CPU probe is out of date and found the new OIDs in Cisco process mib but the one OID either ends in 1000 or 19, this made it difficult to update the Cisco CPU probe but I got it to work, still if you want it to graph you need a separate probe that only graphs.
This functions makes sure you have a valid value before sending it to the probe.
Function;
Description: 1.3.6.1.4.1.9.9.109.1.1.1.1.8.19 or .8.1000 is the cisco process mib oid for 5 minute average across all CPUs. This function returns the first element of that oid_column the first element is 0.
Code: if(array_size(oid_column("1.3.6.1.4.1.9.9.109.1.1.1.1.8", 10, 5)), array_element(oid_column("1.3.6.1.4.1.9.9.109.1.1.1.1.8", 10, 5), 0)+1,"False")
--The above code says if there is an array in the oid, return array element 0 from that array, add 1 for sometimes the CPU is at 0% utilization and return false if there is not an array.
Probe;
When you make the probe, put these for the appropriate fields;
Available: Cisco_CPU_5tot() <> "False"
Error: if(Cisco_CPU_5tot()<>"False",if(Cisco_CPU_5tot() -1<86, "", concatenate("Warning: high CPU = ", Cisco_CPU_5tot(), "%")), "Cisco Device down")
Value: Cisco_CPU_5graph()
Lebowski
Users browsing this forum: No registered users and 3 guests
