vahid
CHR and Google Cloud problem
Sat Dec 17, 2022 2:52 pm
hi all
i have installed CHR on Google Cloud and having some problems with that
first of all i want to share my experience with you :
Google Cloud using MTU 1460 by default and Routeros using MTU 1500 by default
so you should changing eth1 MTU to 1460 or lower,or changing default MTU of Google Cloud.
if you don't doing it,you will have internet on Routeros,but many services not working,for example : you can't renew License on Routeros (you will see Handshake error)
now i have problem with L2TPv3 ip with Google Cloud
i can say everything is working well,except L2TPV3 ip mode.
i disabled Google Cloud firewall totally,but the problem is persist.
i have installed CHR on Linode,Vultr,AWS,Azure and some another DataCenter and working properly
but i don't know how can i solve it with Google Cloud
anyone have any suggestion?
Widmo
Re: CHR and Google Cloud problem
Wed Apr 19, 2023 1:22 am
Hey,
I don't have a solution, but I collided with the same problem.
Clean RouterOS 7.8 uploaded as image, test license added,
ran the test:
/tool fetch url="http://noc.pirx.pl/100mb.bin" mode=http
and the speed is below 1 Mbps.
I have tested different settings and VM interfaces, always, each version has a huge speed problem.
Users browsing this forum: No registered users and 2 guests
