Hiji5656
Does RBGPOE (RBPOE) injectors save for other side hardware?
Sat Dec 24, 2022 2:59 pm
Hi!
I planning to use RBGPOE injector after ISP Router to feed my HAP AC2. Does RBGPOE supply other side with power? risk exists?
ISP R does not support any POE standards. ISP have no experience with POE and recommend not to. They refuse to provide their hardware type...
I tried to find disassembly for injector or schematics or clear answer but no success.
R1CH
Re: Does RBGPOE (RBPOE) injectors save for other side hardware?  [SOLVED]
Mon Dec 26, 2022 11:44 pm
The unpowered side is safe to use with any hardware, it's just a standard Ethernet cable. Power only goes out the powered side - make sure you connect that side to ONLY Mikrotik devices, it's non-standardized passive PoE so it is unsafe to use with any 802.3af/at hardware as it constantly supplies voltage without any sensing.
Hiji5656
Mon Jan 02, 2023 7:33 pm
R1CH, thank you!
I confirm, other side no under Power Source voltage. Voltmeter readings are about 0 for both DC and AC.
I wonder what happen if capacitors short circuit)))
Hiji5656
Another model
Wed Feb 28, 2024 11:07 am
in case of any interest - another model.
Harder to disassemble - tight connection.
Darker body color.
Blue light diode more bright.
Works as expected. Both able to POE-IN POE-OUT set.
Same jack 5.5mm x 2.1mm.
Users browsing this forum: Yahoo [Bot] and 9 guests
