depth0cert
7.8beta3 Broken native private-keys-imported with netinstalled RouterOS
Sat Feb 04, 2023 4:19 pm
SUP-106766 private-keys-imported: 0
NETINSTALLED 7.7 - OK
[admin@MikroTik] > /certificate add common-name=r1-ca days-valid=3652 key-size=prime256v1 key-usage=key-cert-sign,crl-sign name=r1-ca subject-alt-name=email:r1-ca
[admin@MikroTik] > :do {/certificate sign [find name=r1-ca] name=r1-ca} on-error={:delay 3}
  progress: done
[admin@MikroTik] > /certificate export-certificate r1-ca file-name=r1-ca export-passphrase=passphrase type=pem
[admin@MikroTik] > /certificate remove r1-ca
[admin@MikroTik] > /certificate import file-name=r1-ca.crt name=r1-ca passphrase=passphrase
     certificates-imported: 1
            files-imported: 0
       decryption-failures: 0
  keys-with-no-certificate: 0
[admin@MikroTik] > /certificate import file-name=r1-ca.key name=r1-ca passphrase=passphrase
     certificates-imported: 0
     private-keys-imported: 1
            files-imported: 1
NETINSTALLED 7.8beta2 - OK
  progress: done
            files-imported: 0
            files-imported: 1
NETINSTALLED 7.8beta3 - NO
  progress: done
            files-imported: 0
            files-imported: 0
depth0cert
Re: 7.8beta3 Broken native private-keys-imported with netinstalled RouterOS
Fri Feb 10, 2023 12:41 pm
Netinstalled 7.8rc1 - problem has been solved.
Thank you, MT!
Users browsing this forum: No registered users and 1 guest
