Amm0
"serial2http" — container to bridge serial to the RouterOS CLI
Mon Feb 20, 2023 7:05 pm
Problem
RouterOS supports serial via /ports, including serial devices via USB or actual serial ports on the device. While RouterOS allows serial to IP via /ports/remote-access, e.g.
/port remote-access add port=serial0 protocol=rfc2217 tcp-port=22171
But what RouterOS does not have an RFC-2217 client in the CLI and/or RouterOS scripts. e.g. SENDING new serial data to a connected (or remote) serial device – not just exposing a physical port as IP port. One workaround is to create a "/interface/ppp-client" with port set to the serial devices, then commands can be /ppp-out1 at-chat input=" – but that only works with serial devices that have an AT command set. But it be better if "at-chat" was more flexible & perhaps an option on /port/remote-access to inject data on the shared ports.
Not much has changed, so this 2009 posting has more background on serial and RouterOS (viewtopic.php?p=138054&hilit=rfc2217#p138054). The new docs may have some details on new devices and serial support too.
Basically the container improves upon this approach:
https://wiki.mikrotik.com/wiki/Sending_ ... erial_port
Idea: use HTTP to "proxy" serial data via a container
Importantly, since /container does NOT have direct access to the serial ports, so you MUST use /ports/remote-access to use this container with even a directly attached serial device.
RouterOS does a /tool/fetch, but obviously that doesn't work with serial data (or the remote-access ports either)... Since a container can do whatever userland stuff (e.g. no USB/devices), I create one that has a small python script that listens for incoming HTTP request POST'ed, sends via IP-based serial port (e.g. a /port/remote-access), and then returns the response from the serial device in the HTTP response as plain text. So with the "serial2http" container, the following sends "my-data-to-go-to-serial" to a IP-wrapped serial device, and the output is available in CLI:
/tool/fetch url=http://172.22.17.1 method=post http-data="my-data-to-go-to-serial" output=user
(or in scripting by storing the result of /tool/fetch in a variable)
... with Python's PySerial library (in container) as the "glue"
What the container below does is use Python's pySerial library to connect to any serial port exposed as IP, and runs Python's internal HTTP server to listen for commands to send. It looks for a "\n" to know when to return a response. Feel free to adjust the python to your needs – more example here really... Where/how is connected is controlled by env vars to the container:
/container/envs {
    # HTTP port the container listens for commands on...
    add name="$containertag" key="PORT" value=80
    # PySerial "URL" to use to connect to serial device via RFC2217
    add name="$containertag" key="SERIALURL" value="rfc2217://172.22.17.254:22171?ign_set_control&logging=debug&timeout=3"
    # while most options can be set in the pyserial's url, BAUDRATE must be explicit
    add name="$containertag" key="BAUDRATE" value=115200
/container/mounts {
    # serial2http doesn't use mounts
Critical to serial2http container is the PySerial's URL. Please see: https://pyserial.readthedocs.io/en/late ... dlers.html for details on what can be set in SERIALURL envs above. For example, if you set "raw" as type on /ports/remote-access, then use the "socket://" in SERIALURL. All of the work here is done via PySerial so their docs likely very useful to effectively using this container for your own purposes.
Not the python expert – only used it because PySerial has very rich serial support – so LMK if there are issues in the actual Python code. (e.g. It's not clear who closes the files, but seem to happen)
Building the container...
One day I'll publish some containers on GitHub, but you can build this one using the following below.. So I'll presume you have docker tools and know something about it to keep this short.
To build it you really need two files: and so download the following put them in same directory.
- Dockerfile
- serial2http-code.py
Dockerfile
FROM python:3.11-alpine
WORKDIR /usr/src/app
RUN pip install --no-cache-dir 'pyserial>=3.5'
COPY . .
CMD [ "python", "./serial2http-code.py" ]
serial2http-code.py
#!/usr/bin/env python3
import serial
import io
import os
from http.server import BaseHTTPRequestHandler
defserialurl= "rfc2217://172.22.17.254:22171?ign_set_control&logging=debug&timeout=3"
httpport    = os.getenv('PORT', "80")
serialurl   = os.getenv('SERIALURL', defserialurl)
baudrate    = os.getenv('BAUDRATE', "115200")
print(f'port {httpport} serialurl {serialurl} baudrate {baudrate}', flush=True)
class SerialViaHttpPostHandler(BaseHTTPRequestHandler):
    def do_POST(self):
        # use ENV variables – TODO should use some config class...
        global httpport
        global defserialurl
        global serialurl
        global baudrate
        length = int(self.headers.get('content-length'))
        reqdata = self.rfile.read(length)
        self.send_response(200)
        self.send_header('Content-Type', f'text/plain; charset=windows-1252')
        self.end_headers()
        with serial.serial_for_url(serialurl, baudrate=int(baudrate), timeout=5) as ser:
            try:
                cmdin = reqdata
                print(f"cmdin = {str(cmdin)}({type(cmdin)})", flush=True)
                ser.write(cmdin)
                cmdout = ser.readline()
                print(f"cmdout = {str(cmdout)}({type(cmdout)})", flush=True)
                self.wfile.write(cmdout)
            finally:
                print("finished", flush=True)
                ser.close()
# when launched as root script, start listening on HTTP
if __name__ == '__main__':
    from http.server import HTTPServer
    server = HTTPServer(('0.0.0.0', int(httpport)), SerialViaHttpPostHandler)
    print(f'HTTP listening on {str(httpport)}')
    server.serve_forever()
To build it, you can use following command, in the same directory as the two files above:
docker build --platform linux/arm/v7 -t serial2http .
docker save serial2http > ../serial2http.tar
the .tar file will be in the parent directory. You can copy and install on your router, using the envs discussed above to control.
The default networking assumes the following, but change as desired:
:local containernum 1
:local containername "serial2http"
:local containeripbase "172.22.17"
:local containerprefix "24"
:local containergw "$(containeripbase).254"
:local containerip "$(containeripbase).1"
:local containertag "$(containername)$(containernum)"
:local containerethname "veth-$(containertag)"
/interface/veth {
    remove [find comment~"$containertag"]
    :local veth [add name="$containerethname" address="$(containerip)/$(containerprefix)" gateway=$containergw comment="#$containertag"]
    :put "added VETH - $containerethname address=$(containerip)/$(containerprefix) gateway=$containergw "
/ip/address {
    :local ipaddr [add interface="$containerethname" address="$(containergw)/$(containerprefix)" comment="#$containertag"]
    :put "added IP address=$(containergw)/$(containerprefix) interface=$containerethname"
/container/envs {
    remove [find name="$containertag"]
    add name="$containertag" key="SERIALURL" value="rfc2217://$(containergw):2217$(containernum)?ign_set_control&logging=debug&timeout=3"
/container/mounts {
Since this is all insecure traffic, you'd want to think about how best to write up the container (and port used by /port/remote-access).
Anyway this approach seems to work, thought I'd share. No warranties however.
Amm0
Re: "serial2http" — container to bridge serial to the RouterOS CLI
Sat Feb 25, 2023 4:03 pm
Since I want to figure this out anyway. I put this on GitHub, which builds a package to install. See updated version here:
https://github.com/tikoci/serial2http
Sertik
Tue Dec 19, 2023 9:31 am
Thanks a lot to the author for the work done and the instructions for use.
I translated the instructions into Russian for my comrades https://forummikrotik.ru/viewtopic.php?f=14&t=14835. We haven't tried it yet, but we will definitely try it. I wanted to connect the so-called Serial MP3 Player YX5300 to the Microtik via RS-232 so that I could voice and music events on the router.
It's a pity that all this is possible only on ROS7 and RB with ARM processors.
I saw images of a device called "VIADIRECT BOX", including the RB GX450, connected via RS232 to some adapter unknown to me and a 220V relay module for control. This can be seen in the attached images. Moreover, the French company produced them en masse for its "installations". How their RB Microtik controlled the 220V relay module without any container not possible at that time remains a mystery to me. Have you heard anything about this development?
Amm0
Tue Dec 19, 2023 6:41 pm
I'm guessing the board in the photo is using the RouterOS console to read/write CLI commands (like reset or health) — hard to know. e.g. it's not RouterOS script controlling the board, likely the other way around. But dunno.
There is /interface/ppp-client/at-chat that let you talk to serial via script. The BIG downside is that it's designed for a modem using "AT" commands. While the /interface/ppp-client/at-chat will send to any serial port (or USB serial) anything provided in the input="" to the serial device. But at-chat is limited on read the serial responses — it looks for an "OK" in the serial to know to return data to a routeros script to use. No "OK" in response, "at-chat" can't be used.
I suppose the other alternative, if one was more industrious and had free time... would be use V6 and MetaROUTER to do same as the serial2http container above. MetaROUTER did run on older MIPS/etc things. e.g. expose serial as TCP, have openwrt in MetaROUTER use a webserver+python script like above container. But that be a lot of work.
Sertik
Wed Dec 20, 2023 9:46 am
Thank you very much, Amm0 for your answer. If I don't need to receive responses from the device, but only send it commands in the form of hexadecimal code (for example, I need to send 7EFF0603000001EF) via RS232, can I do this via a ppp-out interface like this:
/interface ppp-client add name="scripttemp" dial-on-demand=no port=serial0 modem-init="my data" null-modem=yes disabled=no
:delay 2s
/interface ppp-client remove [/interface ppp-client find name="scripttemp"]
And how to correctly represent the data in order to substitute it in “my data” so that it ends up there not as a string, but as a sequence of bytes? Is it possible ?
Amm0
Thu Dec 21, 2023 12:32 am
Yeah if it's one-way, then ppp-client can work.
The bytes would need to be encoded in a routeros string first:
"\7E\FF\06\03\00\00\01\EF"
Now I dunno if ppp-client init/at-chat allows high ASCII chars or limits the bytes...you'd have to test that.
Sertik
Thu Dec 21, 2023 9:12 am
Thank you very much! I will definitely check it out.
Sertik
Fri Dec 22, 2023 8:33 am
I checked it out.
It doesn't work. My device works fine via the usb-serial adapter CH340, but does not work via ppp-out1.
I think the fact is that the data is not being transmitted correctly.
I will try to connect a Mikrotik cord with a serial-usb adapter to the serial port and look at the terminal program on the PC that is transmitted from ppp-out1.
Amm0
Fri Dec 22, 2023 10:23 am
Did you set the correct baudrate/parity for the serial0 in /port (System > Ports in winbox)?
Sertik
Fri Dec 22, 2023 12:10 pm
of course
Sertik
Fri Dec 22, 2023 12:16 pm
If you pass hexadecimal data as a string:
/interface ppp-client add name="scripttemp" dial-on-demand=no port=serial0 modem-init="\7E\FF\06\03\00\00\01\EF" null-modem=yes disabled=no
Are you sure that the data will be transmitted correctly?
Amm0
Fri Dec 22, 2023 6:30 pm
It will append a newline I believe so there that. If you enable logging on "async" topic, you might get more data too.
I'd try it via "/interface ppp-client at-chat [find] input=", not the modem-init (leave that blank) — I'm not sure what else happens when you start ppp-client... "at-chat" just uses the setting from a ppp-client to know what port to use, but it doesn't require the ppp be active for at-chat to work.
I have no reason believe RouterOS filters the ASCII chars, so it should send escaped string as bytes, but it possible it filter special/high ASCII chars...never tested that part.
Sertik
Sun Dec 24, 2023 3:37 pm
I couldn't get the command to work:
/interface ppp-client at-chat [find] input="\7E\FF\06\03\00\00\01\EF"
If ppp-client is created and active, this command always produces an error: "failure: can't reuse channel while ppp-client running!"
But, I finally managed to send commands to my device through the design:
:delay 1s
At the same time, I first connected the serial-usb CH340 adapter instead of the device and looked at what
comes from the serial consumption of the router.
When ppp-client starts, if modem-init=(nothing), it still sends the sequence to the port 2F 41 75 74 6F 50 50 50 2F 0D 0A 43 4C 49 45 4E 54 and repeats it periodically until it is disabled or deleted. If modem-init= contains something, then something is sent to the port. But for some reason, zero bytes are not transmitted, and if a zero byte is encountered, the data transfer is terminated.
I had to remake the commands to the device so that they did not contain zero bytes, fortunately the command format allows this
For example, command-data "\7E\FF\06\03\00\00\01\EF" can be transferred as "\7E\FF\03\01\EF".
Then my device began to receive normal commands and respond to them.
I would of course like to use the instruction:
but I don’t know how to make it work firstly, and secondly how to transfer \00 bytes
Sertik
Sun Dec 24, 2023 3:59 pm
In addition, it turned out that not all commands for my device can be shortened and there are important commands that require the transmission of sequences containing zero bytes, without which the commands are not perceived. So the main problem is passing zeros (zero bytes)
Amm0
Sun Dec 24, 2023 7:57 pm
Yup, that make sense now that I look at the serial command. In C, \00 (NULL char) is a string terminator...so I guess that percolates to it's processing of script strings.
I was worried about higher ASCII (>128 dec, > 7F hex), but it's the "lowest" ASCII char that seemingly blocks at-chat from working for your particular string.
These vagaries (and that at-chat looks for "OK" and always send a newline) are why I created a container and used IP-to-serial in RouterOS ;)
Sertik
Mon Dec 25, 2023 5:15 am
OK, thank you very much for everything. Solved the problem.
Users browsing this forum: No registered users and 3 guests
