shamsali222
VOIP+ATA
Fri Feb 24, 2023 7:05 am
i am setting up a VOIP+Data VLAN in my company so i can use VOIP Phone Ethernet port to connect the PC to LAN which device you suggest ? is there any documentation for that
MickeyT
Re: VOIP+ATA
Fri Feb 24, 2023 8:16 am
I don't have any recommendations as to equipment you should use or references for documentation but I do have a piece of advice:
A lot of VoIP phones (?all?) will pick up their IP address from the untagged VLAN on the port they're connected to. This means that, when configuring VLANs on the switch port, set the VoIP VLAN as the untagged one and the DATA VLAN as the tagged one. You should also be able to specify the Data VLAN in the VoIP phone's config via its WebGUI.
Backups are your friend. Always make a backup!
/system backup save encryption=aes-sha256 name=MyBackup
k6ccc
Re: VOIP+ATA
Fri Feb 24, 2023 6:17 pm
A lot of that will depend on the capabilities of your VoIP phones.
Your question is rather vague. Are you asking about what network switch to buy to hook your phones to? If so, almost any VLAN capable switch will do if it meets your requirement - primarily the required number of ports.
Users browsing this forum: No registered users and 4 guests
