gmsmstr
Trainer
Trainer
How in v7? Selectivity accept prefixes, not load the rest?
Thu Mar 16, 2023 3:41 pm
I want to load a BGP peer that is sending me full + default.. I need anything that has its AS ONLY, no transit, to come in but everything else to be discarded. Normally I would create a filter that would accept where AS-PATH=AS# then discard the rest, but in v7 can’t discard the rest? the NLRI don't help... Thoughts?
What is the correct method of doing this….
rextended
Re: How in v7? Selectivity accept prefixes, not load the rest?
Thu Mar 16, 2023 3:58 pm
On RouterOS 7, if you use filters, what is not accepted is implicity discarded.
gmsmstr
Trainer
Trainer
Thu Mar 16, 2023 4:09 pm
If you don't specify anything ,it still loads it, it is just filtered :( I want those prefixes to be discarded and not loaded into memory at all... not a option in v7?
rextended
Thu Mar 16, 2023 4:11 pm
I'm not one expert on BGP, but why you can not create filters???
mrz
I believe he means "discard from memory". It is not possible, input-nlri and others are used to discard fast, regexps are not fast so are not available as a method to discard bgp update messages directly.
You can only reject with filters.
gmsmstr
Trainer
Trainer
Thu Mar 16, 2023 4:18 pm
We could do that in v6 :(
gmsmstr
Trainer
Trainer
Thu Mar 16, 2023 5:29 pm
Maybe we need a soft-reconfigure option, i.e. if its turned on as normal, it would function like it does. If we turn it off. A reject will remove it from memory.. ? Would be a simple method of doing it.
gmsmstr
Trainer
Trainer
Thu Mar 16, 2023 10:39 pm
What about if in HW.. If I load 2000 routes, the rest are filtered, does 2000 routes get added to HW only?
mrz
Fri Mar 17, 2023 9:31 am
HW candidate routes can be only active routes and with the HW flag set.
Filtered routes will never be active.
pe1chl
Fri Mar 17, 2023 11:52 am
At least in v6 you had the option to discard with filters (instead of only reject).
The accept-nlri is much more limited because it accepts using an address list, and address lists do not have prefix-length.
For this case you would want to accept 0.0.0.0/0 with prefix length 0, but as an address list 0.0.0.0/0 simply accepts everything.
It would be better when accept-nlri would use some dedicated mechanism that is more like the v6 filtering where you can specify a list of items to be accepted or discarded. That would not need to have slow functions like regexp, just a simple list of prefixes with prefix length range. This case could then be written as:
action=accept prefix=0.0.0.0/0 prefix-len=0-0
action=discard
Splash
Fri Nov 17, 2023 7:57 pm
V7 cannot really cope without a discard rule...especially when using peering route servers on non ARM64 based routers.....
Its crazy that I have 1m (Many RS servers from difference exchanges) routes in my router that the filters have to pass through each time there is a change, when they could be filtered once and discarded.
thesysadmin
Sat Nov 18, 2023 3:49 am
You should be able to accept any routes with an AS Path containing only your provider's AS.
/routing/filter/rule
add chain=myChain rule="if (bgp-as-path 1234) {accept}"
pe1chl
Sat Nov 18, 2023 11:22 am
What he (and others above) is worried about is that such a filter rule only prevents the route to become active. It is still put in the table but as "filtered". That takes up resources.
In v6 such filters would discard the route before it is being stored somewhere.
umiseaz
Thu Apr 18, 2024 3:48 am
Can mikrotik consider to re implemented the discard action? As input accept nlri is defined in address list
Users browsing this forum: dmitris and 7 guests
