BremySohrax
Mikrotik SwOS 2.9 Issues
Thu Mar 23, 2023 8:17 am
I have been using SwOS 2.8 on a CSS326-24G-2S+RM and CRS317-1G-16S+RM without any issues for a long time. Recently, I decided to upgrade to SwOS 2.9 on both devices. I updated the firmware and RouterOS on the CRS-317 before upgrading to SwOS.
However, I started experiencing an error/fault light on the CRS-317 every 12 hours, with the fans running at full rpm. Upon checking, I found that I was getting over 100,000 rx pauses on the trunk between the two devices.
To troubleshoot the issue, I downgraded back to SwOS 2.8 on both devices and the error/fault hasn't reappeared. Have any other users experienced similar problems with SwOS 2.9?
k6ccc
Re: Mikrotik SwOS 2.9 Issues
Sun Mar 26, 2023 2:01 am
You're not likely going to get much of an answer. SwOS 2.9 is ancient. You're 4 major releases behind.
Users browsing this forum: No registered users and 1 guest
