laurenttaieb
Routes default configuration issue
Tue Mar 28, 2023 3:04 pm
Hello Forum,
I'm trying to set up a dual WAN configuration (FTTH + 5G upstream connections) for my home network.
I've used a great method which is available from Router OS 7.3 using reccursive routing, scope and target scope (https://www.youtube.com/watch?v=eTmpBAAW_pQ) but I still have routing issues as apparently some default configuration prevents the route setup to work. When I go into the Route List and try to remove them, RouterOS reinstall them automatically.
I'm not using fib nor masquerade firewall rules.
Can someone tell me what can be done.
I'm pinging far end DNS servers from the 2 to check connectivity from the main router and the packets look to ignore the scope and target scope setup chosing themselves the route to use.
Happy if someone can help.
Laurent
Users browsing this forum: No registered users and 7 guests
