stevedh
WifiWave2 view current frequency
Sat Apr 01, 2023 1:01 pm
Just got a microtik hap ax2, only just getting my head around the interface, but have managed to get everything working.
However, if I'm assuming if I leave frequency blank it will automatically chose a frequency, however I can find no way to view what frequency it has chose.
can this be done and if so how.
Also any way to view what settings are used for other unset values ?
tia
holvoetn
Re: WifiWave2 view current frequency
Wed Apr 26, 2023 11:36 pm
Winbox
Go to wireless, could be the frequency is already shown on the first screen.
If not, double click interface and go to status.
Terminal:
/interface/wifiwave2/actual-configuration print
stevedh
Sun May 07, 2023 11:27 pm
Thanks for the reply..
it was on double click and status...
what confused me is that it is blank on the 1st screen,
robmaltsystems
Long time Member
Long time Member
Sun Feb 04, 2024 5:48 pm
Anyone know how to display/get the frequency from the terminal/script? /interface/wifi/monitor [interface] does display this but can't be used in a script.
jaclaz
Long time Member
Long time Member
Sun Feb 04, 2024 6:34 pm
robmaltsystems
Long time Member
Long time Member
Sun Feb 04, 2024 8:41 pm
Thanks - bit of a fudge but that might work.
Later... indeed it does:
:local interface [/interface/wifiwave2/monitor private-5g as-value once]; :put ($interface->"channel");
Users browsing this forum: Bing [Bot], Pilo2710 and 17 guests
