yan2x
Hotspot not redirecting to login page
Thu Apr 20, 2023 4:22 pm
Its working fine on ROS 6.48.6 after upgrading to ROS 7.8 it stop working.
If I manually type routers IP it will bring me to login page.
I already email the support but no reply since 02/Apr/23 SUP-112422
yan2x
Re: Hotspot not redirecting to login page
Wed Jun 14, 2023 6:08 am
Updated to 7.9.2 still not redirecting... :(
loloski
Wed Jun 14, 2023 11:38 am
Normally when that happen check for the DNS setting you setup for the hotspot, without proper dns settings it won't work just my 0.2$
yan2x
Fri Jun 16, 2023 3:46 pm
viewtopic.php?t=165366
Set arp=local-proxy-arp in interface section and add-arp=yes in DHCP section solved the problem.
is this normal to set?
mkx
Fri Jun 16, 2023 4:35 pm
Normal settings are arp=enabled and add-arp not set. Anything else is set for some particular reason, some "cooking recipes" advise to set arp=reply-only and add-arp=yes to force clients to use DHCP server assigned IP addresses instead of anything else (e.g. manually set IP addresses) ... or arp=proxy-arp to fix some "problem" with communication between clients in different L2 segments (and the reasons to do it are most of times the wrong ones).
yan2x
Fri Aug 11, 2023 1:51 pm
Its not working again on 7.10.2....:(
Users browsing this forum: winap and 2 guests
