qatar2022
RouterOS 2 SwOS and SwOS 2 RouterOS
Fri Apr 21, 2023 9:19 am
Dear all
I have MikroTik CRS328-24P-4S+Cloud Router Switch runs as a switch and I want to change it to SwOS
Can I run CRS328-24P-4S+ as a switch? is their any configure I have to do it with SwOS to run as a switch?
how can I change CRS328-24P-4S+ OS from SwOS to RouterOS ?
with regards
k6ccc
Re: RouterOS 2 SwOS and SwOS 2 RouterOS
Fri Apr 21, 2023 5:41 pm
Yes, you can change from RouterOS to SwitchOS. Rather than me retyping all the instructions, check out this page in the online docs - almost all the way to the bottom. Start at: Configuring SwOS using RouterOS and read all the way to the bottom of the page.
https://help.mikrotik.com/docs/pages/vi ... d=76415036
I would STRONGLY suggest that you make a backup in RouterOS prior to switching to SwitchOS, and conversely making a backup in SwitchOS before changing back to RouterOS.
As far as configuration, I have only made that change once on a CRS326 that is now running SwitchOS, but as I recall, after changing the device to SwitchOS, it is the default SwitchOS configuration. Any config changes will need to be made by you.
Users browsing this forum: No registered users and 0 guests
