diegoncho
Connection between subnets
Thu Apr 27, 2023 2:49 am
Dear forum members,
I am writing to seek your assistance in configuring my MikroTik network. Currently, I have the Ether1 interface with the IP address 192.168.8.6/24 and the Ether4 interface with the IP address 192.168.10.1/24. I would like both networks to be able to communicate with each other without creating a bridge. Is there any other way to achieve this?
I would appreciate it if someone could provide me with information or guidance on how to properly configure my network so that both networks can communicate with each other.
Thank you very much in advance for your attention and help.
rextended
Re: Connection between subnets
Thu Apr 27, 2023 3:04 am
What you mean for "both networks can communicate with each other"?
If you can ping from one device on network A, one device on network B, you have already done.
diegoncho
Thu Apr 27, 2023 3:21 am
I connect to ether1, setting the pc to ip 192.168.8.50/24
and on ether2 a pc with ip 192.168.10.5/24 and they do not ping each other
rextended
Thu Apr 27, 2023 3:27 am
ether2? not ether4?
still not clear what you want obtain.
put the /export of the config on the forum with a network diagram
diegoncho
Thu Apr 27, 2023 4:08 am
ether2? not ether4?
I attach the topology, PC1 has no connection to PC2
attached ping from PC2 to PC1
diegoncho
Thu Apr 27, 2023 4:10 am
ether2? not ether4?
/interface set ether1 address=192.168.8.6/24
/interface set ether4 address=192.168.10.1/24
rextended
Thu Apr 27, 2023 5:02 am
Usually the router do it's work... routing, and if PC firewall do not block nothing, ping is possible.
But... if you have modified the default configuration on the router.... or you leaved the default and ether1 is the wan interface...
Better you post the /export for see how the device is configured.
Censore sensitive data on the export.
diegoncho
Thu Apr 27, 2023 4:54 pm
literally has nothing else.
# jan/02/1970 00:04:44 by RouterOS 6.48.6
# software id = xxxx
# model = CRS312-4C+8XG
# serial number = xxxx
/ip hotspot profile
add address=192.168.8.6/24 interface=ether1 network=192.168.8.0
add address=192.168.10.1/24 interface=ether4 network=192.168.10.0
/system identity
set name=RouterOS
/system routerboard settings
set boot-os=router-os
rextended
Thu Apr 27, 2023 5:22 pm
I don't see any errors, find the problem on PCs, is something missing, like correct subnet, gateway or firewall enabled?
Or is there another device in the middle that is interfering...
PC is once 8.50, then 8.20, why ping 8.25?
And one time it's ether2, the other time ether4...
What a mess...
stmx38
Long time Member
Long time Member
Fri May 05, 2023 6:37 am
On the screen we see that ping is done to the 8.6 and reply is from 8.25. Theoretically should be from 8.20?
@diegoncho, can you please check if you can ping both PC's from the Mikrotik? It will help to identify if something is related to their firewalls.
Users browsing this forum: No registered users and 3 guests
