pinomat
ACL/Switch Rules CCR2116-12G-4S+
Mon May 15, 2023 10:32 am
I need as many other users to change the priority (pcp - 802.1p) of IPv4 DHCP packets (dicover/request) generated by the router DHCP Client. As DHCP requests are using raw socket, firewall are completely ignored. I don't want to use bridges and even if I want to, bridge filter rules only work when we break Mikrotik recommandations (to make DHCP filter rule work, VLAN needs to be slave of bridge port instead of ethernet port).
I know that CCR2116-12G-4S+ only allow ingress rules. But why can't we have ACL egress rules ? Is it a switch chip (98DX3255) limitations ?
Do you have a better way to do that without adding a switch to do this job ?
Thank you
chechito
Re: ACL/Switch Rules CCR2116-12G-4S+
Mon May 15, 2023 6:42 pm
look this post can be related
viewtopic.php?t=196068
pinomat
Fri May 19, 2023 10:34 am
This seems great ! I will accept once 7.10 works for the job ;) I will try it.
Thank you for your answer !
cyayon
Tue Jul 18, 2023 5:17 pm
I am in the same boat. Did you manage to apply ACL rules to change COS of you DHCP client requests ?
thanks.
pinomat
Sat Nov 18, 2023 1:36 am
thanks.
Hello, still no luck as far as today... Even standard vlan/bridge/rule does not answer to my need (I cannot use the filter to limit to mac protocol or udp 67 - I was only able to do that with MAC address to FF:FF:FF:FF:FF:FF)... A 2G Internet connection consumes 5% CPU when using another switch to change pcp of my DHCP packet. While using bridge + bridge filter consumes 15%...
I will continue to wait for a new feature... Honestly, this situation doesn't make any sense to me :(
Users browsing this forum: No registered users and 7 guests
