Hap ax2 7.8 everything works fine.
Upgraded to 7.9 and all clients cannot connect to wifi.
Did experiments with auth types, PMKID, rebooted. Nothing helped.
Downgraded to 7.8 and everything works fine again.
Am I missing something or its a bug in 7.9?
Code: Select all
# may/19/2023 22:29:12 by RouterOS 7.9
add admin-mac=48:A9:8A:7F:5A:21 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] poe-out=off
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=MikroTik-7F5A25 \
security.authentication-types=wpa2-psk,wpa3-psk .disable-pmkid=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=all \
.width=20/40mhz comment="comment1" configuration.country=\
Germany .mode=ap .ssid=mywifi .tx-power=19 disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk .disable-pmkid=yes \
.encryption="" .management-protection=allowed .wps=disable
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment=192.168.99.32/27 name=default-dhcp ranges=\
192.168.99.33-192.168.99.62
add address-pool=default-dhcp interface=bridge lease-time=1d name=defconf
/port
set 0 name=serial0
/queue simple
add max-limit=6M/25M name="Limited clients" target=192.168.99.32/27
/routing table
add disabled=no fib name=vpnz
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
set generic-timeout=2m tcp-established-timeout=1h
set discover-interface-list=all lldp-med-net-policy-vlan=1
/ip settings
set allow-fast-path=no
/ipv6 settings
set disable-ipv6=yes max-neighbor-entries=15360
add address=192.168.99.1/26 comment=defconf interface=bridge network=\
192.168.99.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=10m
/ip dhcp-client
add comment=defconf default-route-distance=2 interface=ether1 use-peer-dns=no \
use-peer-ntp=no
add address=192.168.99.0/26 comment=defconf dns-server=192.168.99.1 gateway=\
192.168.99.1 netmask=26 ntp-server=192.168.99.1
set allow-remote-requests=yes cache-max-ttl=6m servers=\
1.1.1.1,1.0.0.1
established,related,untracked
invalid
add action=drop chain=input comment="!!!! - disabled to log in from WAN defcon\
f: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid dst-address=!192.168.19.0/26 log-prefix=\
drop_invalid
connection-state=new in-interface-list=WAN log=yes log-prefix=\
drop_forward
ipsec-policy=out,none out-interface=ether1
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
/system identity
set name=APRR
/system note
set note="APRR "
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes manycast=yes use-local-clock=yes
/system ntp client servers
add address=0.de.pool.ntp.org
add address=1.de.pool.ntp.org
add address=2.de.pool.ntp.org
add address=3.de.pool.ntp.org
