dragoalato1988
what is correct way to assign simple queue pppoe to parent?
Fri Jun 23, 2023 2:08 am
Hi all, what is the correct way to have pppoe simple queues dynamically created as children of a Parent queue, and update the target list on connection and disconnection?
I was thinking about address lists or interface lists, but it seems the target ignores all of these.
Thank you
chechito
Re: what is correct way to assign simple queue pppoe to parent?
Fri Jun 23, 2023 5:50 am
in PPP-PROFILES
you can customize the profile you are using in pppoe
there you can setup parent queue
dragoalato1988
Fri Jun 23, 2023 7:57 pm
hi, thank you for your reply, yes I have activated the parent node function in the pppoe profile, and the child simple queue is actually created. the problem is that if I don't enter the ip of the pppoe client in the parent node, the bandwidth limits are not applied.
at the moment I have created 2 scripts one for up and one for down which inserts or removes the ip of the pppoe client from the target of the parent queue
can't use target list or address list in target value?
Users browsing this forum: No registered users and 2 guests
