If you read Brochure, it says that these connectors are for an external LTE antenna. So you should connect MIMO 2x2 external 700-2700 Mhz antenna.
Regards.
Hello, I also have Chateau LTE6 ax, ROS 7.14.2, LTE Firmware 16121.1034.00.01.01.04, winbox 3.40. I tried the external antenna mANT LTE 5o and connected ANT1 (antenna) to ANT2 (chateau lte6 ax) and ANT2 (antenna) to ANT3 (chateau lte6 ax).
By default settings are:
[admin@MikroTik] > /interface lte settings print
mode: auto
firmware-path: firmware
external-antenna: none
[admin@MikroTik] >
But:
- I do not see External Antenna drop down at Interface List -> LTE -> Modem
- I do not see the Antenna Scan button at Interface List -> LTE
However, I'm able to change the setting as follows:
[admin@MikroTik] > /interface lte settings set external-antenna=both
but it looks like does not take any effect.
Can someone advise is this expected behavior, or this device does not support such antenna and I need something like HGO-LTE-W?
Thanks!
