Bumping up this thread. This is beyond unbelievable - copy pasting from Notepad was NEVER a problem with ROS 6. Pasting ROS 6 config to ROS 7 console malforms the lines.
I always thought, that Notepad = clean text input / output and I am usually using it as a middle ground to copy paste across apps, and it always works. Not so with Mikrotik ROS 7 console.
And you know what? I have tried something completly crazy - I have copy pasted the config to MS Word. And man, it just works. MT should win some special prize for curing out the MS Word inefficiencies!
So plese, Mikrotik - could you fix this apparent buggy copy paste experince? And please, don't suggest using other editor apart from Notepad - you know, I've got the MS Word already
Might be read as funny experience, except it's not - there will be many ppl trying to get their config from ROS 6 to ROS 7 generation. We should make their experience easier, not the opposite.
