Skinfaxi
hAP lite RB041-2nD how to update?
Mon Aug 07, 2023 9:03 pm
i bought just a tre hAP lite RB941-2nD. I try to update it but i get an error message "not enough diskspace"
screenshot: https://ibb.co/dBCGsy6
is their a workaround?
holvoetn
Re: hAP lite RB041-2nD how to update?
Mon Aug 07, 2023 9:26 pm
Don't bother.
Not enough space.
You can try with netinstall but the next version you will run into the same problems.
Skinfaxi
Wed Aug 23, 2023 11:50 am
Don't bother.
Not enough space.
Yeah, that doesn´t sound good. Has Mikrotik no ambition to keep their devices up to date?
Its a bit odd that i am unable to update devices that i purchages just days ago...
erlinden
Wed Aug 23, 2023 12:59 pm
You are talking about a low end device that was introduced in 2015 (and probably earlier) that stil receives updates. What other brand does that? Did you buy the correct device (and are you expectations correct)?
As mentioned...there is a workaround by using netinstall. If you stick to V6.x LTS, you won't get that many updates.
Ca6ko
Long time Member
Long time Member
Wed Aug 23, 2023 3:56 pm
Find the fix-space-6.47-smips.npk file on the net, copy it to your device and reboot it. After that there will be enough free space for updating.
This problem appeared and was solved back in 2020-21. Apparently your device has been in the distributor's warehouse since then
PS viewtopic.php?t=181442
onnoossendrijver
Wed Aug 23, 2023 3:58 pm
Why not do a netinstall with the latest v6 version?
Ca6ko
Long time Member
Long time Member
Wed Aug 23, 2023 4:02 pm
Sometimes there is only remote access to the device
martking
Mon Dec 18, 2023 12:57 am
Worked great thank you for the info :D
Users browsing this forum: Bing [Bot], Siarap and 4 guests
