fashice
std failure the dude no group option
Fri Aug 11, 2023 10:51 am
Hi All,
I've got some weird issues using wifi, so I wanted to use the Dude (spectral scan) to look into this problem.
But when trying to do so I get a std failure.
I've looked at the posts mentioned below, any suggestions what to do?
With regards,
# Screenshots of the router settings and the dude
# std failure post, with read group being metioned
viewtopic.php?t=126631
# post about group permission retired
viewtopic.php?p=992515&hilit=group#p992515
# Router RB4011iGS+5HacQ2HnD
# RouterOS 7.9
# TheDude version ? downloaded yesterday
Jimmy
Re: std failure the dude no group option
Mon Aug 14, 2023 1:50 pm
Same issue here
fashice
Fri Aug 18, 2023 12:29 pm
Same issue here
Any progress on your side?
stmx38
Long time Member
Long time Member
Tue Aug 22, 2023 6:49 pm
Just did a try and got slightly different error
std failure: broken path (2)
Differences from your screen
1. No issue with permission - just used user with full admin permissions
2. Can see interface in the list - in your case there is (unknown) probably because of the permissions
Versions
# NAME       VERSION
0 routeros   7.11
1 dude       7.11
Posts with similar error
1. Dude v3.5 - Mon Jan 04, 2010 2:14 pm
2. Cannot login Mikrotik thru winbox as well as webbox - Thu Mar 01, 2012 9:05 am
3. Dude agent not work - Sat Oct 08, 2016 11:17 am
4. CPU usage stuck at 100% on RB750GL - Tue Oct 18, 2016 9:36 pm
5. "get settings failed: std failure: broken path (2)" - Fri Oct 21, 2016 1:40 pm
6. std failure: broken path (2). what is this? - Thu Aug 23, 2018 3:48 pm
7. Spectral Scan not working in The Dude 7.7 - Sun Feb 26, 2023 1:53 pm
Screenshot
stmx38
Long time Member
Long time Member
Tue Aug 22, 2023 7:15 pm
And some explanations - Spectral Scan not working in The Dude 7.7
Mikrotik devices on new chips do not support spectral scan
Hi, Mikrotik Support said me the same.
Spectral Scan on new devices with wifiwave2 package is not planned now. 😡
I can't understand why 🤔
It's really a bad news and now the only solution is go with Ubiquiti.
Sorry Mikrotik
fashice
Thu Sep 07, 2023 7:14 pm
besides spectral scan maybe not supported, i can't even see the interfaces.
but i saw some logging about login failure from local ip's
(ip configured on the MT)
Maybe I have to reinstall the dude package
Users browsing this forum: No registered users and 2 guests
