lordgosub
SFP+ incompatibility with UF-INSTANT SFP
Thu Aug 17, 2023 7:36 pm
Hello.
I'm trying to use UF-INSTANT https://store.ui.com/us/en/products/uf-instant with the Netpower 16P.
The UF-INSTANT only really works when you plug-in and auto negotiation is ON. If you reboot the Mikrotik or you disable-enable the SFP port, it doesn't come back. For make it work, psychically you have to re-plug it. If you disable auto negotiation and set 1G FULL manually, the Mikrotik says that link is OK, but is not true.
On the other hand, on CCR1036-12G-4S those SFPs works perfect with no issues.
I try changing the LAN_SDS_MODE on the UF-INSTANT, but it's not helping.
Any help will be so much appreciated.
mkx
Re: SFP+ incompatibility with UF-INSTANT SFP
Thu Aug 17, 2023 8:47 pm
Which ROS version? The behaviour you described was reported previously and MT did introduce some changes in recent ROS versions. Not sure if the fix really works (and 100% of time) though.
lordgosub
Thu Aug 17, 2023 9:31 pm
First, thank you for your time.
I tested v6 long term, v7 stable and v7 develop.
All of those do the same thing.
I didn't forget to upgrade the firmware too on each test.
lordgosub
Thu Aug 17, 2023 11:01 pm
I read somewhere that swos 2.12+ broke the sfp+ compatibility, but I' m unable to downgrade it since there's no link available
lordgosub
Fri Aug 18, 2023 3:45 pm
I answer myself:
Official support provided me the swos 2.11, but sadly with this version the SFP never goes UP.
Users browsing this forum: No registered users and 7 guests
