complete2006
Hap AX2 max CPU temp
Sat Aug 19, 2023 10:58 am
Hi!
I know that the devices are tested up to 50 deg ambient temp. Any number for max allowed CPU temp?
holvoetn
Re: Hap AX2 max CPU temp
Sat Aug 19, 2023 10:18 pm
Cpu itself ?
Real max 80-85C I would think.
Should be somewhere in the spec sheet of that processor ?
berisz
Thu Aug 24, 2023 11:38 am
Very good question!
I could not find any reference to the "Tj.Max" of the "Qualcomm IPQ-6010" SoC.
This limit varies by CPU type and is usually between 100°C and 105°C.
Other sources say that above 85°C there can be possible damage.
In general, it is said that it is recommended to keep the sustained (continuous) temperature below 65°C.
Rox169
Thu Aug 24, 2023 12:02 pm
Mine AX2 and AX3 has aroun 60 without any load...but with complicate config
gseeu
Fri Nov 03, 2023 2:07 pm
But what is the cpu idle temperature in AX2?
My AX2 has 55C when idle, is it okay?
erlinden
Fri Nov 03, 2023 2:13 pm
Just checked, around 53C here.
MrYan
Fri Nov 03, 2023 3:40 pm
Mine is also 53C in the UK. Co-incidence I hope, rather than a stuck temperature reading!
holvoetn
Fri Nov 03, 2023 3:41 pm
51C in Belgium, acting as simple wifi AP in small closet.
Users browsing this forum: No registered users and 9 guests
