zepcenas
cant get cpu temperature in script
Fri Aug 25, 2023 10:01 pm
Hello
I'm having some trouble figuring this out. This is a RB5009
On the terminal:
/system health print
Columns: NAME, VALUE, TYPE
# NAME VALUE TYPE
0 cpu-temperature 54 C
/system health get number=0
[nothing]
/system health get value-name=temperature (just to show that doesn't work)
input does not match any value of value-name
/system health get value-name=cpu-temperature
Script:
:log info "$[/system identity get name] $[/system health print] testing";
outputs: router testing
How can get router temperature in a script?
Thank you
msatter
Re: cant get cpu temperature in script
Fri Aug 25, 2023 10:50 pm
Have a read overhere: viewtopic.php?t=198614
rextended
Re: cant get cpu temperature in script  [SOLVED]
Sat Aug 26, 2023 9:41 am
The correct syntax would have been /system/health get "cpu-temperature" value if the RouterOS programmers had made one thing uniform with everything else.
But since "cpu-temperature" is not already solved like other sections, [find where name=cpu-temperature] is needed.
So, the needed command line is:
    :local cputemp [/system/health get [find where name=cpu-temperature] value]
    :put $cputemp
eldoncito2019
Sat Aug 26, 2023 12:51 pm
REX:
How do I make the script appear in green letters like you do. Thanks for teaching.
rextended
Sat Aug 26, 2023 1:10 pm
Use the "code display" button [ ] ...........
or manually...
[code]script[/code]
zepcenas
Sat Aug 26, 2023 6:17 pm
    :put $cputemp
Thank you Rex. I see it now.
Users browsing this forum: No registered users and 8 guests
