Hello, there's new feature called Back To Home (BTH) soon, that makes accessing routers even without public IPs really easy:
1) install latest 7.12beta (no problem, BTH has been tested successfully since 7.11)
2) mark dynamic DNS and Back To Home checkboxes in IP -> Cloud
3) Install Wireguard client into your Windows (you have to have admin rights to use it)
4) copy-paste configuration from web/winbox
5) That's it, you are able to safely connect to your router without any portforwarding or hard configuration.
But I want to Access my LAN network (Like all ubnt devices) that's why I need a VPN.
Is your recommended solution work for that al my needs?
Regards
