miankamran7100
Access local web server with public IP with 443 port. 443 Port Forwarded not working
Tue Aug 29, 2023 11:09 am
Dear all,
I have a Web server on Debian 11. which is accessible with 443 ports in the browser.
Locally it is accessible on my all LAN Computers.
But I want to access it with a public IP
I have a forward port 443. but I not working even though I see packets are coming on this rule.
But not accessible on the web
erlinden
Re: Access local web server with public IP with 443 port. 443 Port Forwarded not working
Tue Aug 29, 2023 11:22 am
Can you please share the config, instead of posting screenshots?
/export file=anynameyoulike
Make sure to remove serial and any other private information (like public IP).
Are your other port forwards working?
miankamran7100
Tue Aug 29, 2023 1:24 pm
please help me in this regards
add name=Bridge_LAN
add name="Bridge_LAN Central Park"
set [ find default-name=ether1 ] name=ether1_WAN
/interface pppoe-client
add disabled=no interface=ether1_WAN name=PPPoE_PTCL user=abc
add name=dhcp_pool ranges=192.168.110.11-192.168.110.250
add address-pool=dhcp_pool interface=Bridge_LAN name=dhcp1
/port
set 0 name=serial0
/routing table
add disabled=no fib name=VPN
add bridge=Bridge_LAN interface=ether3
add bridge=Bridge_LAN interface=ether4
add bridge=Bridge_LAN interface=ether5
set discover-interface-list=all
/ipv6 settings
set disable-ipv6=yes
add address=192.168.110.1/24 interface=Bridge_LAN network=192.168.110.0
add address=192.88.16.1/24 interface=Bridge_LAN network=192.88.16.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-server lease
add address=192.168.110.101 always-broadcast=yes comment="Windows 10 Laptop" \
mac-address=74:70:FD:1D:CE:23
add address=192.168.110.102 always-broadcast=yes comment="Windows 11 Laptop" \
mac-address=74:E5:F9:D1:59:F2
add address=192.168.110.0/24 dns-server=192.168.110.1,8.8.8.8,8.8.4.4 \
gateway=192.168.110.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.110.3 name=airavenue.contegris.com
add action=accept chain=input comment="Router Access Remotely" dst-port=\
4477,4478 protocol=tcp
add action=accept chain=input comment="Web Allow" dst-port=53 in-interface=\
Bridge_LAN protocol=tcp
Bridge_LAN protocol=udp
add action=drop chain=input comment="Block Attack" dst-port=\
25,53,87,512-515,543,544,7547,8080 protocol=tcp
53,80,87,161,162,1900,4520-4524,8080 protocol=udp
add action=add-src-to-address-list address-list="Port Scanners" \
address-list-timeout=none-dynamic chain=input comment=\
"Port Scanners to Address List " protocol=tcp psd=21,3s,3,1
"TCP Flag-NMAP FIN Stealth scan" protocol=tcp tcp-flags=\
fin,!syn,!rst,!psh,!ack,!urg
"TCP Flag-FIN/SYN scan" protocol=tcp tcp-flags=fin,syn
"TCP Flag-RST/SYN scan" protocol=tcp tcp-flags=syn,rst
"TCP Flag-FIN/PSH/URG scan" protocol=tcp tcp-flags=\
fin,psh,urg,!syn,!rst,!ack
"TCP Flag-ALL/ALL scan" protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg
"TCP Flag-NMAP NULL scan" protocol=tcp tcp-flags=\
!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=input comment="Dropping Port Scanners" \
src-address-list="Port Scanners"
add action=masquerade chain=srcnat src-address=192.168.110.0/24
add action=dst-nat chain=dstnat dst-address=xx.xx.xx.xx dst-port=4481 \
protocol=tcp to-addresses=192.168.110.101 to-ports=3389
add action=dst-nat chain=dstnat dst-address=xx.xx.xx.xx dst-port=4482 \
protocol=tcp to-addresses=192.168.110.102 to-ports=3389
add action=dst-nat chain=dstnat comment="Web Server" dst-address=\
xx.xx.xx.xx dst-port=447 protocol=tcp to-addresses=192.168.110.103 \
to-ports=443
add disabled=no dst-address=0.0.0.0/0 gateway=PPPoE_PTCL routing-table=main \
suppress-hw-offload=no
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=4478
set ssh disabled=yes
set www-ssl disabled=no
set api disabled=yes
set winbox port=4477
set api-ssl disabled=yes
/system clock
set time-zone-name=Asia/Karachi
/system identity
set name="Air Avenue"
/system note
set show-at-login=no
/tool romon
set enabled=yes
erlinden
Tue Aug 29, 2023 2:36 pm
May I ask who took care of this firewall?
You might want to consider bringing it back to default...that saves a lot of time analyzing the problems you run into.
While we are at it...if you place the export in between code tags </>, your post will become more readable.
Will update my answer with recommendations while reading the config.
  • Remove "Bridge_LAN Central Park"
  • Remove "add address=192.88.16.1/24 interface=Bridge_LAN network=192.88.16.0"
  • /ip firewall filter
    Why? Think you don't want to become a DNS server for the web!? And remote access to the router (what service??)...don't! Winbox access through WAN...never! Port obfuscation...no security at all!
  • add action=drop chain=input comment="Block Attack" dst-port=\
    You already allowed DNS access above, why block it here!?
I'm done, perhaps @anav or @mkx (or any other firewall expert) want to take the opportunity to optimize this crap.
miankamran7100
Tue Aug 29, 2023 3:00 pm
I have all the DNS for accessing the Web server on my LAN.
and I have blocked the DNS for the wan port.
because it consuming my internet speed. (DNS attack)
erlinden
Tue Aug 29, 2023 3:05 pm
Now I see...it is allowed only via bridge.
Still...please consider going back to defaults (which will protect you a lot better) or even better...block everything on the end of both input and forwarch chain. Just be aware to allow everything you want explicitely.
You are aware that you do not have any filter rules on the forward chain?
peterda
Tue Aug 29, 2023 3:16 pm
Is it intentional that you want to forward 443 to 447?
to-ports=443
Ignore if intentional :lol:
miankamran7100
Tue Aug 29, 2023 3:34 pm
to-ports=443
also trying to change or port nating. but could not.
Users browsing this forum: Bing [Bot] and 9 guests
