AlohaSpark
Static Routes + BGP - Routers can ping each other, but won't pass traffic through it (ingress and egress)
Tue Aug 29, 2023 5:49 pm
NOTE: All the IP addresses below are examples, and are not my actual public IP addresses.
I have a Mikrotik located on my ISP's premises. I also have a /24 block and ASN, which is announced just fine.
[admin@MikroTik] > /routing/bgp/advertisements/print
 0 peer=bgp1 dst=49.123.123.0/24 afi=ip nexthop=111.222.222.111 origin=0 as-path=sequence 123456
I then established a VxLAN tunnel between the ISP and my local MT. I assigned the IP addresses as in the below diagram.
Lastly, I added a static route on the ISP-side MT:
[admin@MikroTik] /ip/route> export
add blackhole disabled=no distance=200 dst-address=49.123.123.0/24
add disabled=no dst-address=49.123.123.3/32 gateway=192.168.123.2 routing-table=main
 │                    │         │                     │      IPv4 BGP
 │     Mikrotik 1     │         │     Mikrotik 2      │     Full table
 │ vxlan-local        │◄───────►│ vxlan-2             │          │
 │  192.168.123.2/30  │  VxLAN  │  192.168.123.1/30   │          │
 │  49.123.123.3/32   │         │                     │          │
 │                    │         │ eth1-WAN            │          │
 │ eth1-WAN           │         │  111.222.222.111/24 ├──────────┘
 │  Normal internet   │         │  49.123.123.2/32    │
 │ eth2-LAN           │         │                     │
 │  Normal LAN        │         │                     │
I confirmed that the local MT can ping ISP-MT (192.168.123.1), and ISP-MT can ping local MT (192.168.123.2 and 49.123.123.3). Additionally, I can ping ISP-MT (111.222.222.111 and 49.123.123.2) from the outside, which is great. BGP is working, and static routing works I think.
The issue is I can't ping local MT from outside. Am I missing anything?
BGP works, both routers can talk to each other, but outside can't access local MT.
Currently at a loss. Any help will be appreciated.
pe1chl
Re: Static Routes + BGP - Routers can ping each other, but won't pass traffic through it (ingress and egress)
Tue Aug 29, 2023 7:09 pm
Do you have a firewall configuration?
AlohaSpark
Tue Aug 29, 2023 7:27 pm
Currently, no. Both MikroTiks have zero firewall/NAT rules.
StubArea51
Trainer
Trainer
Fri Sep 01, 2023 12:35 pm
Is the peering iBGP or eBGP between the routers?
What address are you trying to ping and where does it stop if you traceroute?
AlohaSpark
Re: Static Routes + BGP - Routers can ping each other, but won't pass traffic through it (ingress and egress)  [SOLVED]
Fri Sep 01, 2023 2:34 pm
It's eBGP between ISP my Mikrotik (on their premises). I then tried to set a static route to that remote MT and my local MT.
All good now, it seems to have been a Windows issue rather than the routers (which were apparently working the whole time).
Currently now have OSPF and appropriate filters between the two MTs.
Users browsing this forum: No registered users and 1 guest
