Hello, I have a script for pppoe that creates a rule in Routing Rules, but the non-active rule is in red. I can enable or disable the terminal it does not activate. But if it is in the rule via graphical interface to disable and re-enable it works could you help me?
Thank you very much
Follows the command:
