I am trying to install CHR on a fresh Hetzner Cloud CCX13 VM (this is a new lineup with dedicated CPU cores on AMD hardware).
I'm following the official docs verbatim (hetzner-doc,mikrotik-doc):
- create vm
- boot into rescue mode
- download and write raw image
Commands executed in rescue console:
Code: Select all
# zero /dev/sda
dd if=/dev/zero of=/dev/sda bs=1M
# write latest image to /dev/sda
curl -L https://download.mikrotik.com/routeros/7.11.2/chr-7.11.2.img.zip | funzip | dd of=/dev/sda bs=1M
# reboot
reboot now
After rebooting the VM won't boot.
Attaching to the console windows shows the following error message:
Code: Select all
BdsDxe: failed to load Boot0002 "UEFI QEMU QEMU HARDDISK " from PciRoot (0x0)/Pci(0x2,5x5)/Pci(0x0,0x0)/Scsi(0x0,0x0): Not Found
>>Start PXE over IPv4.
I managed to locate a somewhat similar error message in combination with the new Hetzner lineup: reddit
Here the threads OP writes:
I wrote Hetzner a ticket and got a reply earlier today, apparently there's a workaround but I haven't tried it yet:
CCX\3 models are provisioned using UEFI.
Any ideas or insights are greatly appreciated.
