Lightningpillz
Route down log indication
Mon Sep 04, 2023 5:05 pm
Looking to implement a check to confirm if routes are up and running for various subnets. Trying to get it working with Netwatch and an output to log at the moment but a major issue in the Loop that my inferior scripting skills have not managed to solve, so I turn to the forum for assistance.
Thanks to @Jotne for getting me this far with his post viewtopic.php?p=888800#p888800
Netwatch:
Host - 8.8.8.8
Up - Pointing to script "Test"
Down - Pointing to script "Test"
Script:
Name - Test
Source -
:local Host $host
/tool netwatch
:local Status [get [find where host="$Host"] status]
:while ($Status="down") do= {:log error "Down"}
This currently outputs an endless barrage of error log "Down" without end, only way I've found is a reboot. How can I get this error message to loop every minute if the netwatch status is marked as down and then to stop when status is up?
rextended
Re: Route down log indication
Mon Sep 04, 2023 7:11 pm
This currently outputs an endless barrage of error log "Down" without end.
Is exactly what you want/write:
while $Status is down, write to error log "Down"...
If you had written instead:
if $tatus is down, write to error log "Down"...
Lightningpillz
Tue Sep 05, 2023 9:46 am
Had already tried this however with logic it only outputs to log once. How would one go about getting this to repeat until the Status is noted as "up"?
:local Host $host
/tool netwatch
:if ($Status="down") do={:log error "ITS DOWN"} else={:log error "ITS UP"}
Lightningpillz
Re: Route down log indication  [SOLVED]
Fri Sep 08, 2023 4:36 pm
ChatGPT gave me the answer
:while ($Status="down") do={
    :log error "Down"
    :delay 1000ms
    :set Status [get [find where host="$Host"] status] #THIS needs to check the var every time
Users browsing this forum: No registered users and 7 guests
