mohanad1989
Ethernet - link down
Mon Sep 04, 2023 5:49 pm
I'm currently facing an intermittent issue with a link going down and then coming back up on the CCR2004-16G-2S+ RouterOS 7.11, affecting both the WAN and LAN ports and consequently impacting the service.
I've taken several steps to address the problem:
-Replaced the cables.
-Manually configured the interface speed to 1 Gbps after disabling auto-negotiation.
-Deactivated loop protection.
-Restarting the device.
Example of the recurring log entries appear as follows every few minutes:
22:16:44, interface, info ether1- link down.
22:16:47, interface, info ether1- link up (speed 1G, full duplex).
I'm actively working on resolving this issue to restore stable connectivity.
any help is appreciated
Thank you
mkx
Re: Ethernet - link down
Mon Sep 04, 2023 8:39 pm
7.11.1 changelog contains quite a few items mentioning bridge and stability in same sentence. Some mentioning bugs introduced in 7.10 or 7.11 ...
Beware that 7.11.1 contains a bug in DHCP server, so you probably want to upgrade to 7.11.2.
mohanad1989
Tue Sep 05, 2023 4:42 am
Thank you, I upgraded tp OS 7.11.2, Hope the issue will be resolved
mohanad1989
Tue Sep 05, 2023 8:29 am
Unfortunately, after upgrading to OS 7.11.2, the issue still exists.
patrickmkt
Tue Sep 05, 2023 1:50 pm
I also had my ether 1 port going up and down recently on a CCR1036.
I too changed cables without success.
I have not found the solution yet, but for the time being, I migrated to another eth port that was available to get my system running.
mohanad1989
Tue Sep 05, 2023 7:56 pm
If I'm the case is only ether1 then im ok can change the port, but its happening in all used ports! The issue wasn't happening on os 6.49 only happens with os 7
I hope mikrotik do something about it
mkx
Tue Sep 05, 2023 10:04 pm
Such things are hard to replicate. So ideally you would create a supout.rif file while any of ports are down and another one soon after the flapping port gets up again. Then open a support ticket and provide both files to MT. That would give them chance to figure out what's happening.
mohanad1989
Wed Sep 06, 2023 5:06 am
Thank you, I have upload the support.rif to Mikrotik support hope they reply me
mohanad1989
Thu Sep 07, 2023 12:54 pm
Here is a screenshot, can anybody help me?
Ca6ko
Long time Member
Long time Member
Thu Sep 07, 2023 1:17 pm
Category 6 cables? If yes, try changing to cat5
mohanad1989
Thu Sep 07, 2023 1:27 pm
I already tried to change the cables, and this issue is not happening with our router running Os 6.49 only the router with Os 7
which I suspect is software or hardware issue
Ca6ko
Long time Member
Long time Member
Thu Sep 07, 2023 10:21 pm
downgrade 7.8
mohanad1989
Fri Sep 08, 2023 6:29 am
downgrade 7.8
Thank you for your suggestion, I done downgrade but the issue still happen
Ca6ko
Long time Member
Long time Member
Fri Sep 08, 2023 9:17 am
Downgrade the version until the problem goes away
mohanad1989
Fri Sep 08, 2023 5:01 pm
I downgraded until 7.4.1 which is the factory firmware and still happen!!!
mohanad1989
Mon Sep 11, 2023 4:45 pm
I installed a Switch between WAN and Mikrotik and noticed it worked without the port dropping!
Like in the photo below
any idea why?
beeonline
Wed Sep 27, 2023 9:09 am
I have many towers where i get link flapping.
Some of them happen every day, others - randomly.
Many just don't flap at all.
The switches i use are CRS326
Not i have 2 main places where it happens a lot:
CRS326 + LHG60
There are other LHG60's in the same spot and only one would drop the link. Cable has been replaced, no change.
CRS326+UBNT PowerBeam AC5 Gen2
It randomly switches to 1gbit, than drops to 100mbps a hundred times a day.
After some time it will stop flapping and works ok, than next day it starts again.
SNR in the ubnt antenna is 30 at all pairs..
I use the same shielded cable for the links.
UPD:
And now when i disabled auto negotiation,
interface status says 100mbps full duplex, but in the powerbeam it says 100mbps half duplex. Which one to trust?
FW versions are latest for today (CRS326 was 6.47 until today, but nothing changed after upgrade both FW+Bootloader)
mkx
Wed Sep 27, 2023 10:59 am
You should trust both sides ... because without auto negotiation each side uses whatever it's set to do. In your case you have a duplex-mismatch which can (and will) disrupt traffic occasionally (more if link is loaded higher). So by all means change settings so that they match on both sides. I'd go with full duplex unless you encounter some problems.
flyingduck
Thu Nov 09, 2023 6:14 pm
any idea why?
hello, I encountered the same problem as you, you image link is down, could you please re-upload it again, how to put the switch, this problem has haunted me for so long.
mada3k
Long time Member
Long time Member
Thu Nov 09, 2023 8:45 pm
Are you using shielded cables?
Soochi
Tue Nov 21, 2023 1:02 pm
This seems like a new thing cause i started experiencing this and all ports go off and on affecting connection stability.
Try2StopMe
Tue Nov 28, 2023 10:27 am
The same goes for CCR2004-16G-2S+, RouterOS v7.12.1. There are random port drops
djani
Thu Nov 30, 2023 9:58 am
Hello.
I have the same problem with my: CRS354-48P-4S-2Q+ I have four of them.
All have random port drops.
Changing Cables didn't help, upgrade and downgrade also.
Switching off Poe also didn't help either.
Currently they working on verssion: 7.12.1
I'm out of ideas.
20061985
Sat Dec 02, 2023 9:58 am
Hi everyone.
I want to tell the same story with CCR2004-16G-2S+, RouterOS v7.12.1.
Half of the ethernet ports are simultaneously going down at the same time for a few seconds. That happens with ports that are located on switch 2 inside the Mikrotik. please see the attached image.
1. mohand1989, could you check if that happens with all of your ports or if it is related to ports on one internal switch?
2. If someone from Mirkotik will read it. I would like some advice on what can I do with it.
Thank you.
toquanghieu
Fri Jan 05, 2024 2:47 pm
I get same issue with my rb5009 on 2.5G port, do you have any idea to fix it
Simonth
Fri Jan 26, 2024 8:26 pm
Same issue on a brand new CRS312-4C+8XG-RM aswell, both on 7.13.3 and on 7.13.2. On 7.13.2 it worked fine for about a day before it started happening, on 7.13.3 the links started to go down/up after 5mins.
Nisma
Sat Feb 03, 2024 5:28 pm
Experiencing same issue on RB2011UiAS
Users browsing this forum: Siarap and 4 guests
