agonzalez
disable "Login By Trial"
Tue Sep 05, 2023 8:58 pm
how can i disable and enable "Login By Trial" in hotspot server profile using a script
mohmadtnnarii
Re: disable "Login By Trial"
Fri Sep 29, 2023 8:10 pm
hello
peace be upon you
yes you can
use this script for enable trial time
 ip hotspot profile set login-by=http-chap,https,http-pap,mac-cookie,tria
l [find name=xxx]
and use this script for disable trial time
 ip hotspot profile set login-by=http-chap,https,http-pap,mac-cookie [find name=xxxxxx]
edit (xxxxxx) to your profile name and edit (login-by) and set any Choose the options that suit you
Users browsing this forum: No registered users and 8 guests
