In wifiwave2 quite a bit of those requested parameters are not available (yet).
Roaming only works within the same ROS instance.
This means radios on the same AP, or radios controlled by the same CAPSMAN controller.
AC2 and AX2 are different wifi technologies and can not be controlled by the same ROS instance.
So you are actually comparing apples to oranges here ...
What you can do (no real roaming but to "guide" the change-over process a bit), is use access list to limit signal levels of a client device and actively kick it out when a certain threshold is reached.
Be aware though there are clients which do not respond too well to such behavior (i.e. they may try to avoid an AP doing that).
But do I understand correctly you are trying to use AX2 or AC2 as client ?
How do you move those ?
As i m not romaing on ros at all, that does not apply, as it was stated before, using ruckus,
I m not comparing the techonology/hw,... was just looking where did those options/functions went , sice ax2 is newer model, was interpreted as more powerful in the ad...etc, which is great, but since its missing a lot of features, than its a lot worse / non viable than "its ac2 counter part"
i m comparing those 2 cause of size, poe in / out and 2,4 and 5ghz wifi, 5x 1gbps ports
Is there any roadmap when the romaing will work or if even is going to be implemented outside of ros ?
as for the moving them around, they are on robots that drive themselfs across the warehouses.
ac2 is being used now, with "station roaming" enabled, that takes about second to roam... ax2 since its missing that, does not...
