mehr463
wifi hardware reset issue on hap ax3
Tue Sep 12, 2023 11:48 pm
Hello friends,
Randomly (once a day or so) "Wifi hardware reset" happens on my hap ax3 router when I create and use a virtual wifi on the wifiwave2 5ghz interface.
But the virtual wifi on wifiwave2 2Ghz interface is not like that and it works correctly.
I tried to use any OS alpha and beta 7.12 software maybe this problem will be solved but they didn't solve the problem.
Does anyone have experience with this?
Thank you
sasswaz
Re: wifi hardware reset issue on hap ax3
Wed Oct 25, 2023 11:07 am
Hey, I am getting the exact same issue with the latest software 7.12 on both 2.4 and 5ghz. Any help will be greatly appreciated!
jnob
Thu Nov 02, 2023 6:59 pm
me 2.
Filed a support request: SUP-133058
igreg
Tue Nov 21, 2023 11:51 am
I am experiencing the same issue. Filed a support request (SUP-135071).
I am getting wireless hardware reset periodically, sometime every 10-20 minutes, sometimes less often.
mehr463
Sat Dec 02, 2023 1:15 pm
Hello
I filed a support request for “wifi hardware reset” issue too but they did not give me a convincing answer.
Even upgrade to RouterOs 7.13rc2 made the wifi problem worse.
What should be done in this case?
Why the mikrotik development team do not solve this problem?
jnob
Sat Dec 02, 2023 9:00 pm
See my issue SUP-133058. I (seem to have) discovered that my Apple IOS devices, via the default feature “Private Wi-Fi Address”, were "causing" the problem. After turning off that feature on such devices in my network I no longer see the issue. Of course I would hope that Mikrotik is pursuing the issue and finds a fix for the problem on their side.
mehr463
Sun Dec 03, 2023 10:09 am
Hello
Thank you for sharing your experence about this issue. I will test it and turn off “Private Wi-Fi Address” on all my apple devices and share the result here.
By the way, I could not find your conversation with the supporter (request number SUP-133058).
jnob
Sun Dec 03, 2023 7:09 pm
mehr463
Sun Dec 03, 2023 8:30 pm
Thank you for sharing the link. But it shows me bellow permission error.
I disabled the “Private Wi-Fi Address” on all my apple devices and the “Wifi Hardware Reset” has not happened so far.
That’s great and thank you.
jnob
Mon Dec 04, 2023 5:18 pm
ahh, I guess the bug reports aren't publicly visible...
mehr463
Mon Feb 19, 2024 7:51 am
Hello dear friends
Due to a number of reports about the 'Wi-Fi hardware reset" problem to the support team and its relation with the "private address" of Apple devices, I was hoping that Mikrotik would at least make an improvement in router OS 7.14, but unfortunately, the problem still exists.
What should be done about this?
Santi70
Mon Feb 19, 2024 1:30 pm
I manage two routers where there are iPhones, I started searching and I didn't find that error in any of them and I don't remember seeing it before, so it must be linked to some particular configuration
1 hAPax3 (router and capsman) with 1 hAPax2 (AP) both with v 7.13.4
1 hAPac2 (router) with v 7.14rc1
erlinden
Mon Feb 19, 2024 2:18 pm
Can you share your config, @mehr463? I have neither seen this error on my environment.
mehr463
Mon Feb 19, 2024 7:14 pm
This issue occurs when I create a virtual wifi on the 5ghz wifi interface and use it for apple devices.
Interestingly, creating and using virtual Wi-Fi on the 2.4 GHz Wi-Fi interface does not cause such a problem.
Of course, this issue occurs for Apple devices that have a “private wifi address” set on them, and if I turn off the “private wifi address” or do not create and use 5 GHz virtual Wi-Fi , the problem never appears.
Thanks to the user JNOB who found the relation of apple devices “private wifi address” to this problem.
andreacar
Tue Feb 27, 2024 4:47 pm
Hi All,
I have the same problem.
Wifi interfaces reset and wifi1(5Ghz) stay on DFS scanning.
Thtanks
KKTK
Mon Mar 18, 2024 9:16 pm
Yes, this happening also on hAP ax2 (v7.13.5). Usually once per month.
Santi70
Wed Mar 27, 2024 11:47 am
Today I found this problem also in the logs
bhayduko
Fri Apr 05, 2024 3:03 pm
Hi Guys,
I'm experiencing similar behaviour since last week, but I don't think its caused by Apple device. I'm suspecting my HP Elitebook G9 causing it. Do you know if support is investigating what's going on? And do you have any idea how to understand what exactly is going on? For now I'm trying to use 2.4GHz interface as workaround
robmaltsystems
Long time Member
Long time Member
Wed Apr 10, 2024 3:05 pm
There are quite a few posts on SA Query Timeout. Getting same myself with my Lenovo laptop with Realtek NIC and hAP ax2.
infabo
Forum Veteran
Forum Veteran
Wed Apr 10, 2024 5:00 pm
The real interesting thing is: people go mad because of a log info entry. 🤔
robmaltsystems
Long time Member
Long time Member
Wed Apr 10, 2024 7:11 pm
Well I do because it preludes my laptop falling back to 2.4GHz with a perfectly strong signal ;-)
xypista
Wed Apr 17, 2024 5:57 pm
Same issue started happening after I connected my new company laptop with Intel Wi-Fi 6E AX210 adapter.
I had no problem with using an iPhone that had "Private Wi-Fi Address" turned on and another laptop with Intel Wi-Fi 6 AX201, and I used those for a long time.
Maybe this iPhone setting is only problematic if certain other wireless devices are present? Or maybe my company laptop has some weird Wi-Fi setting?
The 5GHz wifi completely stops working after this. The interface needs a disable/re-enable to make it work (or a device reboot).
holvoetn
Thu Apr 18, 2024 8:45 pm
I have Intel AX211 in my laptop, no issues whatsoever connecting to AX3.
But what's the difference ?
Users browsing this forum: ddregs, GoogleOther [Bot], Guntis, sbert and 12 guests
