Can you
netinstall the device? It's the definite way of getting rid of any kind of germs that might lurk in dark corners of device's storage.
Note that netinstall is a pretty fragile process and it's important to really follow the procedure from the document I linked. There are reports that linux netinstall is a bit more robust than windows ...
And a gotcha: with fairly recent versions of ROS/routerboot it's possible to disable some features, one of them being reset button. Read about Protected routerboot in
routerboot manual.
