miankamran7100
SSTP Client is connected reachable in Main Router terminal not reachable on desktop
Fri Sep 15, 2023 9:31 am
Dear all,
SSTP Client is connected and reachable in Mikrotik Router. But I couldn't able to ping on my LAN / LAN desktop
help, please
Kind regards
Last edited by miankamran7100 on Sun Sep 17, 2023 6:12 pm, edited 1 time in total.
anav
Re: SSTP Client is connected reachable in Main Router terminal not reachable on desktop
Fri Sep 22, 2023 3:57 pm
What are you trying to do?
Reach Router SSTP service remotely?
Reach your own SSTP Server on the LAN remotely
Reach your own SSTP server on the LAN from the LAN?
miankamran7100
Sun Sep 24, 2023 9:13 pm
Yes, I want to Access the SSTP Client Router with the SSTP remote IP. But not able to Access Router of remote site (which is my SSTP Client) not able to ping on desktop.
anav
Mon Sep 25, 2023 2:24 am
What you said makes no sense.......
Either you want to connect to the SSTP that is an available service on the router or not.
If not, then you must be running an SSTP server on a device on a LAN subnet of the router, or NOT.
What is the purpose of the SSTP connection. What requirement does it fulful. Which users needs to use it and for what purpose.
miankamran7100
Mon Sep 25, 2023 10:46 am
i have R1 which is sstp server
R2 client sstp remote ip 172.16.0.96
R3 client sstp remote ip 172.16.0.97
i want to winbox access R2 with remote ip 172.16.0.96
i want to winbox access R3 with remote ip 172.16.0.97
but couldn't.
both R2 and R3 reachable in R1 terminal but not reachable on LAN.
hope u understand.
Kraken2k
Fri Oct 06, 2023 5:06 pm
I assume that "not reachable from LAN" means, that you cannot ping R2 or R3 from a workstation connected to R1 and (probably) this workstation shares the same network range with R2 and R3.
If that's the case, you probably forgot to set the "proxy-arp" on the local LAN interface on R1 - as described in the manual: https://wiki.mikrotik.com/wiki/Manual:I ... ote_Client - so the the connection fails, because IP cannot be translated to destination MAC address as ARP request stays without any response (because those sstp interfaces does not have L2 connectivity to the rest of your LAN).
PS: the new version of documentation does not contain this info> https://help.mikrotik.com/docs/display/ROS/SSTP I wonder why...
Amm0
Fri Oct 06, 2023 5:14 pm
You need a NAT rules for traffic from LAN IP's to the SSTP server's address (action=masquerdade with 172.16.0.0/24 as src). Otherwise the far-end routers (SSTP clients) will have no idea how to send packet to your LAN (e.g. say your main LAN is 10.10.10.0/24, so unless that was a /ip/route to 172.16.0.1 (SSTP Server).
You might also have firewall filter that's blocking this is, but the above may the first problem. If you post your config, I'm sure @anav's firewall eyes will spot the problem.
Amm0
Fri Oct 06, 2023 5:21 pm
FWIW proxy-arp may also work too. But I suspect Mikrotik is trying to steer folks to Layer3 routing to solve, vs "arp tricks".
miankamran7100
Mon Oct 09, 2023 11:51 pm
thanks for your reply
please see my configuration
I have posted
add frame-types=admit-only-vlan-tagged ingress-filtering=no mtu=1500 name=\
Bridge1_VLAN vlan-filtering=yes
add dhcp-snooping=yes mtu=1500 name="Bridge2_Head office" priority=0x1000
add dhcp-snooping=yes mtu=1500 name="Bridge3_Farm house"
set [ find default-name=ether1 ] name=ether1_WAN-1
set [ find default-name=ether2 ] name=ether2_WAN-2
set [ find default-name=ether3 ] name=ether3_WAN-3
set [ find default-name=ether4 ] name=ether4_WAN-4
set [ find default-name=ether5 ] name=ether5_WAN-5
set [ find default-name=ether6 ] name=ether6_Trunk
set [ find default-name=ether7 ] name="ether7_WAN PTCL"
set [ find default-name=ether8 ] name="ether8_WAN Head office"
set [ find default-name=ether9 ] name="ether9_WAN Farm house"
set [ find default-name=ether10 ] disabled=yes
set [ find default-name=ether11 ] disabled=yes
set [ find default-name=ether12 ] disabled=yes
set [ find default-name=ether13 ] name="ether13_LAN Farm house"
set [ find default-name=ether14 ] name="ether14_LAN Farm house"
set [ find default-name=ether15 ] name="ether15_LAN Head office"
set [ find default-name=ether16 ] name="ether16_LAN Head office"
/interface pppoe-client
add disabled=no interface="ether9_WAN Farm house" name="PPPoE_Farm house" \
user=tahir1212
/interface eoip
add local-address=203.223.173.66 mac-address=02:8D:ED:1E:50:BF name=\
"EoIP Tunnel_Air Avenue" remote-address=182.176.86.181 tunnel-id=11458
add local-address=172.16.0.1 mac-address=02:6D:1C:E9:08:5A name=\
"EoIP Tunnel_IT Tower" remote-address=172.16.0.96 tunnel-id=12458
add local-address=172.16.0.1 mac-address=02:FC:41:78:94:F4 name=\
"EoIP Tunnel_Midland" remote-address=172.16.0.97 tunnel-id=13458
add name="WAN PrimeNet List"
/ip firewall layer7-protocol
add name=Speed regexp="^.+(speedtest).*\\\$"
add name="dhcp_pool Head Office" ranges=172.16.3.1-172.16.3.254
add name="dhcp_pool Farm House" ranges=192.168.100.10-192.168.100.250
add address-pool="dhcp_pool Head Office" interface="Bridge2_Head office" \
name=dhcp1
add address-pool="dhcp_pool Farm House" interface="Bridge3_Farm house" name=\
dhcp2
/routing table
add disabled=no fib name="to_Internal Network"
add disabled=no fib name=kamran
add disabled=no fib name="to_PPPoE Farm house"
#error exporting "/interface/bridge/host" (timeout)
add bridge=Bridge1_VLAN frame-types=admit-only-untagged-and-priority-tagged \
interface=ether1_WAN-1 pvid=101
interface=ether2_WAN-2 pvid=102
interface=ether3_WAN-3 pvid=103
interface=ether4_WAN-4 pvid=104
interface=ether5_WAN-5 pvid=105
add bridge=Bridge1_VLAN frame-types=admit-only-vlan-tagged interface=\
ether6_Trunk
add bridge="Bridge2_Head office" interface="ether16_LAN Head office" trusted=\
yes
add bridge="Bridge2_Head office" interface="ether15_LAN Head office"
add bridge="Bridge2_Head office" interface="EoIP Tunnel_Air Avenue"
add bridge="Bridge2_Head office" interface="EoIP Tunnel_IT Tower"
add bridge="Bridge2_Head office" interface="EoIP Tunnel_Midland"
add bridge="Bridge3_Farm house" interface="ether14_LAN Farm house"
add bridge="Bridge3_Farm house" interface="ether13_LAN Farm house" trusted=\
yes
set discover-interface-list=all
/ipv6 settings
set disable-ipv6=yes forward=no
/interface bridge vlan
add bridge=Bridge1_VLAN tagged=ether6_Trunk vlan-ids=101
add bridge=Bridge1_VLAN tagged=ether6_Trunk vlan-ids=102
add bridge=Bridge1_VLAN tagged=ether6_Trunk vlan-ids=103
add bridge=Bridge1_VLAN tagged=ether6_Trunk vlan-ids=104
add bridge=Bridge1_VLAN tagged=ether6_Trunk vlan-ids=105
/interface l2tp-server server
set one-session-per-host=yes
add interface="ether8_WAN Head office" list="WAN PrimeNet List"
add interface="ether9_WAN Farm house" list="WAN PrimeNet List"
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=172.16.0.1/16 comment="Headoffice LAN" interface=\
"Bridge2_Head office" network=172.16.0.0
add address=192.168.0.1/24 comment="Headoffice LAN" interface=\
"Bridge2_Head office" network=192.168.0.0
add address=192.168.210.2/30 comment="WAN PTCL" interface="ether7_WAN PTCL" \
network=192.168.210.0
add address=203.223.173.67 comment="Port Forward Kamran Arif" interface=\
"ether8_WAN Head office" network=203.223.173.64
add address=203.223.173.68 comment="Port Forward FreePBX" interface=\
add address=192.168.100.1/24 comment="Farmhouse LAN" interface=\
"Bridge3_Farm house" network=192.168.100.0
add address=203.223.173.66/28 comment="WAN PrimeNet" interface=\
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-server alert
add disabled=no interface="Bridge2_Head office" valid-server=\
DC:2C:6E:8A:84:7C
add address=172.16.0.0/16 gateway=172.16.0.1
add address=192.168.100.0/24 gateway=192.168.100.1
set allow-remote-requests=yes cache-size=10000KiB servers=8.8.8.8,8.8.4.4
/ip firewall address-list
add address=mail.urbandevelopersgroup.com list="Email Server"
add action=accept chain=input comment="Router Access Remotely" dst-port=\
4477,4478 protocol=tcp
add action=drop chain=input comment="Block Attack" dst-port=\
25,53,87,512-515,543,544,7547,8080 protocol=tcp
53,80,87,161,162,1900,4520-4524,8080 protocol=udp
add action=add-src-to-address-list address-list="Port Scanners" \
address-list-timeout=none-dynamic chain=input comment=\
"Port Scanners to Address List " protocol=tcp psd=21,3s,3,1
"TCP Flag-NMAP FIN Stealth scan" protocol=tcp tcp-flags=\
fin,!syn,!rst,!psh,!ack,!urg
"TCP Flag-FIN/SYN scan" protocol=tcp tcp-flags=fin,syn
"TCP Flag-RST/SYN scan" protocol=tcp tcp-flags=syn,rst
"TCP Flag-FIN/PSH/URG scan" protocol=tcp tcp-flags=\
fin,psh,urg,!syn,!rst,!ack
"TCP Flag-ALL/ALL scan" protocol=tcp tcp-flags=fin,syn,rst,psh,ack,urg
"TCP Flag-NMAP NULL scan" protocol=tcp tcp-flags=\
!fin,!syn,!rst,!psh,!ack,!urg
add action=drop chain=input comment="Dropping Port Scanners" \
src-address-list="Port Scanners"
add action=accept chain=forward disabled=yes dst-address=8.8.8.8 \
out-interface="ether8_WAN Head office"
add action=drop chain=forward disabled=yes dst-address=8.8.8.8 out-interface=\
"ether7_WAN PTCL"
add action=accept chain=forward disabled=yes dst-address=8.8.4.4 \
out-interface="ether7_WAN PTCL"
add action=drop chain=forward disabled=yes dst-address=8.8.4.4 out-interface=\
/ip firewall mangle
add action=mark-routing chain=prerouting comment="Internal network" \
dst-address=192.168.0.0/24 new-routing-mark="to_Internal Network" \
passthrough=yes src-address=172.16.0.0/16
dst-address=192.168.100.0/24 new-routing-mark="to_Internal Network" \
add action=mark-connection chain=prerouting comment="SAP RDP" dst-address=\
116.203.172.113 dst-port=7745 new-connection-mark="SAP RDP_Conn" \
passthrough=yes protocol=tcp
add action=mark-packet chain=prerouting connection-mark="SAP RDP_Conn" \
new-packet-mark="SAP RDP_Pkt" passthrough=yes
add action=mark-connection chain=prerouting comment="PMS WEB" dst-address=\
116.203.172.113 dst-port=8095,8099,44501 new-connection-mark=\
"PMS WEB_Conn" passthrough=yes protocol=tcp
add action=mark-packet chain=prerouting connection-mark="PMS WEB_Conn" \
new-packet-mark="PMS WEB_Pkt" passthrough=yes
add action=mark-connection chain=prerouting comment="Email Server" \
dst-address-list="Email Server" new-connection-mark=Email_Conn \
passthrough=yes
add action=mark-packet chain=prerouting connection-mark=Email_Conn \
new-packet-mark=Email_Pkt passthrough=yes
add action=mark-connection chain=prerouting comment=Speed layer7-protocol=\
Speed new-connection-mark=Speed_Conn passthrough=yes
add action=mark-packet chain=prerouting connection-mark=Speed_Conn \
new-packet-mark=Speed_Pkt passthrough=yes
add action=accept chain=prerouting comment="Farmhouse => Head office" \
src-address=192.168.100.0/24
add action=mark-routing chain=prerouting new-routing-mark=\
"to_PPPoE Farm house" passthrough=yes src-address=192.168.100.0/24
"to_PPPoE Farm house" passthrough=yes src-address=172.16.0.107
add action=masquerade chain=srcnat comment="Masquerade Local Network" \
src-address=192.168.0.0/24
add action=dst-nat chain=dstnat comment="Port Forward Kamran Arif" \
dst-address=203.223.173.67 dst-port=4480 protocol=tcp to-addresses=\
172.16.0.102 to-ports=3389
add action=dst-nat chain=dstnat comment="Port Forward Wavetec" disabled=yes \
172.16.0.240 to-ports=3389
add action=dst-nat chain=dstnat comment="FreePBX SIP NAT" disabled=yes \
dst-address=203.223.173.68 dst-port=5060 in-interface=\
"ether8_WAN Head office" protocol=tcp to-addresses=172.16.0.66 to-ports=\
5060
add action=dst-nat chain=dstnat disabled=yes dst-address=203.223.173.68 \
dst-port=5060 in-interface="ether8_WAN Head office" protocol=udp \
to-addresses=172.16.0.66 to-ports=5060
dst-port=5061 in-interface="ether8_WAN Head office" protocol=tcp \
to-addresses=172.16.0.66 to-ports=5061
dst-port=5061 in-interface="ether8_WAN Head office" protocol=udp \
dst-port=5090 in-interface="ether8_WAN Head office" protocol=tcp \
to-addresses=172.16.0.66 to-ports=5090
dst-port=5090 in-interface="ether8_WAN Head office" protocol=udp \
dst-port=9000-9500 in-interface="ether8_WAN Head office" protocol=udp \
to-addresses=172.16.0.66 to-ports=9000-9500
dst-port=10000-20000 in-interface="ether8_WAN Head office" protocol=udp \
to-addresses=172.16.0.66 to-ports=10000-20000
add action=dst-nat chain=dstnat comment="Hair-Pin NAT" disabled=yes \
dst-address=203.223.173.68 to-addresses=172.16.0.66
/ip firewall raw
add action=drop chain=prerouting comment="Block Windows update" content=\
autodesk.com disabled=yes
update.microsoft.com disabled=yes
add action=drop chain=prerouting content=download.microsoft.com disabled=yes
add action=drop chain=prerouting content=.windowsupdate.com disabled=yes
add action=drop chain=prerouting content=ntservicepack.microsoft.com \
disabled=yes
add action=drop chain=prerouting content=stats.microsoft.com disabled=yes
add action=drop chain=prerouting content=wustat.windows.com disabled=yes
add action=drop chain=prerouting content=windowsupdate.microsoft.com \
disabled=yes
add comment="PTCL Static Route" disabled=no distance=2 dst-address=0.0.0.0/0 \
gateway="192.168.210.1%ether7_WAN PTCL" pref-src="" routing-table=main \
scope=30 suppress-hw-offload=no target-scope=10
add comment="Farmhouse Static Route" disabled=no distance=1 dst-address=\
0.0.0.0/0 gateway="PPPoE_Farm house" pref-src="" routing-table=\
"to_PPPoE Farm house" scope=30 suppress-hw-offload=no target-scope=10
add comment="PrimeNet Static Route" disabled=no distance=1 dst-address=\
0.0.0.0/0 gateway="203.223.173.65%ether8_WAN Head office" pref-src="" \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
gateway="192.168.210.1%ether7_WAN PTCL" pref-src="" routing-table=\
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=4478
set ssh disabled=yes
set api disabled=yes
set winbox port=4477
set api-ssl disabled=yes
/ppp secret
add local-address=172.16.0.1 name=ittower profile=default-encryption \
remote-address=172.16.0.96 service=sstp
add local-address=172.16.0.1 name=midland profile=default-encryption \
remote-address=172.16.0.97 service=sstp
/system clock
set time-zone-name=Asia/Karachi
/system identity
set name="Central Park"
/system logging
set 2 disabled=yes
/system note
set show-at-login=no
/tool romon
set enabled=yes
Users browsing this forum: jaclaz, novasys and 2 guests
