emppu
CRS309 + Intel X520 no link
Sun Sep 17, 2023 2:42 am
I purchased CRS309 with a few tranceivers and cables for homelab. Tried different setups and only DAX works.
1. CRS309 - DAX - Intel X520 = works
2. CRS309 - Wiitek Mikrotik-compatible RJ45 Transceiver (new) - STP Cat 7 - Wiitek Transceiver - Intel X520 = no link, no carrier
3. CRS309 - AIO Transceiver (used) - OM4 Fiber - AIO Transceiver - Intel X520 = no link, no carrier
Intel X520 (options ixgbe allow_unsupported_sfp=1 + EEPRROM patched)
Settings for enp8s0:
	Supported ports: [ FIBRE ]
	Supported link modes:   10000baseT/Full
	Supported pause frame use: Symmetric
	Supports auto-negotiation: No
	Supported FEC modes: Not reported
	Advertised link modes:  10000baseT/Full
	Advertised pause frame use: Symmetric
	Advertised auto-negotiation: No
	Advertised FEC modes: Not reported
	Speed: Unknown!
	Duplex: Unknown! (255)
	Auto-negotiation: off
	Port: FIBRE
	PHYAD: 0
	Transceiver: internal
I have no other 10G equipement to test each component separately.
Q1. Is CRS309 picky about transceivers? Does CRS309 have any vendor lock?
Q2. The wiki (https://wiki.mikrotik.com/wiki/MikroTik ... ity#S+RJ10) says
Use these modules only in 10G SFP+ ports with auto-negotiation enabled
But my X520 does not support auto-negotiation. Does it mean I cannot use CRS309 + X520 with a cat7 copper cable?
Q3. Can I connect CRS309 Port1 and Port2 (loop?) to test tranceivers and cables?
ConradPino
Re: CRS309 + Intel X520 no link
Mon Sep 18, 2023 9:25 pm
CRS309-1G-8S+IN operates with eight (8) Arista Networks SFP-10G-SR at 10Gbps.
emppu
Fri Sep 22, 2023 1:32 am
Thanks for the data sample.
It turns out the issue is all about auto-negotiation. After diabling auto-neg in the ports the fiber started to work. 10GBASE-T still doesn't work but I found the spec says auto-neg is mandatory for 10GBASE-T so it's understandable.
Users browsing this forum: No registered users and 8 guests
