RcRaCk2k
BGP Templates copies instead of references
Sun Sep 17, 2023 11:14 pm
Hi Guys,
is it me or is it ROSv7 that drives me crazy?
I add a BGP Template.
I use that created template in new BGP-Connection. I click OK and all the parameters from Template will be copied into the new BGP-Connection, instead of being referenced to the template (at view only).
When i change the RouterID on Template, it changes also the Connection. But i should not see that values on BGP-Connection in Winbox. I can not see them on terminal.
RcRaCk2k
Re: BGP Templates copies instead of references
Mon Sep 18, 2023 1:46 am
After reboot all template-values were applied to my connection-entity.
That is not okay!
Users browsing this forum: No registered users and 2 guests
