Hi Guys ,
My first post here and hoping for some guidance.
Moving into a new dc soon and we decided on using two CRS326-24S-2Q+ as our new TOR switches.
The design in my mind is quite simple: We have 2 x Fortigate 200E that will serve as our Firewall's with all breakouts and connections terminating on there. ( there are also a bunch of vlans configured on there that are used by hyperv on the vm's so the vlan network that the vm belongs to is selected on there on its Hyperv nic)
We have a Hyper Cluster consisting of 2 x Dell FX2 chassis and their hosts.
There will be two network links to each TOR switch / One from each firewall going to be using port 24 on each switch for these links.
I need these links to then pass all vlan traffic to all ports on the CRS326 , So that we only need to select the vlan it belongs to on the hyperv network card.
We have it running like this currently using the existing cisco's we have as TOR but when we move to the new DC they will stay behind , my experience with Mikrotik is limited so i was hoping for some guidance so i can get this working on the day.
I was thinking SWOS mode would probably be the simplest mode or what would you guys suggest ?
Thank you for the help ahead of time
