diasdm
2.5G PoE Managed switch
Fri Sep 22, 2023 4:54 pm
I was looking for a multi-gig managed PoE switch with at least 8x 2.5G PoE ports and a 10G uplink port.
Does Mikrotik have a 2.5G PoE managed switch with at least 8x 2.5G PoE ports and a 10G uplink port?
holvoetn
Re: 2.5G PoE Managed switch
Fri Sep 22, 2023 6:00 pm
No,
Mikrotik does not have a 2.5G PoE managed switch with at least 8x 2.5G PoE ports and a 10G uplink port, yet.
Newest CRS310-8G+2S+IN is 8x 2.5G and 10Gb SFP but no POE.
POE version might become available (or not) but nobody will be able to tell when.
Mikrotik usually does not reveal such info until the device is released.
popcorrin
Thu Nov 09, 2023 10:04 pm
If mikrotik releases a poe variant of the CRS310-8G+2S+IN we will buy hundreds of them. @Normis do you want to share if this might be in the works?
gotsprings
Fri Nov 10, 2023 1:03 pm
After the lessons learned of the CRS354...
YOU BUY ONE OF THEM. You beat the hell out of it and make sure it keeps working. Then after you shake out any "undocumented features"... you buy a few. Once you test those... then you move on.
sirbryan
Fri Nov 10, 2023 6:12 pm
If you open up the new CRS310, you'll see lots of interesting stuff related to POE on the circuit board...
popcorrin
Mon Nov 13, 2023 11:14 pm
We've had real good luck with the css610 and the crs112 but then again we've been surprised with other mikrotik products in the past.
Users browsing this forum: CoMMyz, MatoZ, stigger and 7 guests
