mjmabs
Detection of CAPsMAN AP Type
Wed Sep 27, 2023 2:00 am
Attempting to detect architecture-name of the remote CAPs either from the CAPsMAN or WiFiWave2 equivalent screen. in process of updating a script that goes out and downloads the correct upgrade files from an internal server for both the Router and the needs of the CAPsMAN/WiFiWave2 CAPS's but can not find a way to use "get architecture-name " under the caps-man area. Obviously we could just manual set the script for type needed but was trying to make it more universal.
Already been done the road of just use /system package and check for updates but this doesn't work in our environments as not all devices connect to the outside world.
holvoetn
Re: Detection of CAPsMAN AP Type
Wed Sep 27, 2023 5:19 am
You mean this ?
Using CLI
mjmabs
Wed Sep 27, 2023 7:46 pm
Nope, trying to detect architecture-name such as arm, arm64, tile, mipsbe, hence which routeros file is needed to upgrade them.
From cli you can run /system resource get architecture-name and it will respond with devices correct architecture-name but under CAPsMAN I have not found a way to detect architecture-name of remote CAPs.
holvoetn
Wed Sep 27, 2023 8:21 pm
Use a mapping table then.
BTW capsmap ap on wifiwave2 are all arm or arm64, unless I missed something.
Ps idea: use snmp calls with correct OID to fetch architecture ?
Users browsing this forum: rabbitkiller and 6 guests
