i take it routerOS is better then SwitchOS then?
The only advantages of SwOS over RouterOS are a simpler web UI and cheaper single-boot products. (There exist dual-boot RouterOS + SwOS switches in the CRS line.) In terms of raw functionality, though, there's nothing SwOS can do that RouterOS cannot. If you find yourself believing otherwise, it will be due to the feature going under a different name, not because it's missing.
The main problem with that plan is that the CSS line is SwOS-only. You'd have to upgrade to
its bigger brother to get RouterOS, which costs $50 more per switch for the rack-mount version. For that, you get a RouterOS license and the more powerful CPU needed to run it.
i should switch over to RouterOS to get the WOL to work?
It's not clear at this point whether the problem is due to SwOS being incapable of doing what you want or that you have a local configuration problem which you could eventually overcome. That said, at least with RouterOS you have
better debugging tools to chase the problem further.
it says you need to login to access support i use my credientials and tells me i didnt type them in right yet i can post in the forms..
The forum and support sites use separate login schemes. And for extra fun, there's the sales site which uses yet a third login scheme.
maybe the switch is getting the WOL packets and just dropping them?
It's possible to debug that without upgrading to RouterOS. Use the port-mirroring features to copy traffic from one port to another, then set up Wireshark on a PC to examine what goes past. With a small number of probes, you can trace the packets' complete path through the switches. It should be interesting to learn the point at which the packets disappear.
