xrlls
String lengths
Fri Sep 29, 2023 12:10 pm
I am writing a script that fetches the latest release note and forwards and excerpt to a server backend, put I am struggling with no text showing of the release note is long.
An example:
tool/fetch  http://upgrade.mikrotik.com/routeros/7.12beta7/CHANGELOG
:put [file/get CHANGELOG contents ]
Results in no output, while if doing the same with a (much) shorter release note it works:
tool/fetch  http://upgrade.mikrotik.com/routeros/7.11.2/CHANGELOG
Results in the release note being shown as expected.
I suspect that I am running in to some limitation of ROS string lengths, but I am not sure if I somehow can work around this.
Any suggestions are much appreciated! :)
msatter
Re: String lengths
Fri Sep 29, 2023 12:42 pm
The problem is not the variable but that fetch retrieves up 64KB and then you have to use chunking if you want more data.
rextended
Re: String lengths
Fri Sep 29, 2023 3:48 pm
Why uselessly do that?
Simply the backend read https://upgrade.mikrotik.com/routeros/7 ... /CHANGELOG
xrlls
Re: String lengths  [SOLVED]
Sat Sep 30, 2023 11:29 am
I agree that it would be more efficient to let the backend handle it. But the backend is beyond my control.
I got it working using this approach:
global test [/tool/fetch "http://upgrade.mikrotik.com/routeros/7.12beta9/CHANGELOG" output=user as-value]
Instead of having the intermediate step where it is stored as a file.
Users browsing this forum: No registered users and 5 guests
