I have problems with SwOS v2.17. From the looks of it, ICMP packets are lost.
I had to go back and downgrade to version 2.14. This version runs without these problems.
My CSS610 is connected via LACP (active) to a pfSense 2.7 (Fast mode, Layer 2,3,4) on a Supermicro X11SCL-iF board. Since the update I get messages that igb0 and igb1 interfaces are flapping at the same time.
I do not see any errors on the switch in the error tab, but sometimes errors are displayed on the link tab with impossible lengths, which after a tab change and back either don't appear anymore or appear with different values and states.
Sometimes it catches, but often dpinger exits, routing stops and internet connection hangs.
I tried it with changed settings and also with disabled IGMP snooping.
Is there any way to view more info or logs at the switch?
