olivier2831
Advice on configuring Mikrotik devices with Ansible
Fri Oct 13, 2023 10:05 am
I'm quite used now to manage Debian hosts with Ansible.
I would like to also manage Mikrotik RouterOS device with Ansible.
The whole picture is:
- using Flashfig to initialize the platform (management IP, firmware, certs, creds, management accounts, enabling/disabling protocols, ...)
- using Ansible to set IP addresses and VLAN, firwalling
Which Ansible module shall I favor first (and why) as some seem to use SSH while some use RouterOS API ?
Are you aware of Mikrotik directly contributing to these modules ?
Best regards
olivier2831
Re: Advice on configuring Mikrotik devices with Ansible
Fri Oct 13, 2023 10:11 am
When using CLI to configure RouterOS, I had trouble to script idempotent operations such as "create VLAN 10 if it doesn't exist".
I don't mean it's not possible to write idempotent scripts with CLI, I only mean I had trouble doing so.
One expected benefit from using Ansible is to ease idempotent configuration.
irrwitzer
Fri Oct 13, 2023 1:07 pm
Hi Olivier,
I dind't find a perfect ansible module for this, when I was searching in early 2022. Maybe things have changed, but I'm currently using
https://docs.ansible.com/ansible/latest ... index.html
collections:
  - community.routeros
For basic stuff. It's not really indempotent though.
Other links in my notes:
https://yetiops.net/posts/ansible-for-n ... -routeros/
https://docs.ansible.com/ansible/latest ... guide.html
memelchenkov
Fri Oct 13, 2023 2:20 pm
Check TR069 instead, will it work for you or not.
olivier2831
Fri Oct 13, 2023 2:23 pm
Does TR069 support VLAN configuration (ie not just for WAN port but for bridge or interface) ?
Users browsing this forum: Ahrefs [Bot], GoogleOther [Bot] and 1 guest
