the configuration of my router bellow:
# 2023-10-25 08:40:18 by RouterOS 7.11.2
# software id = ****
# model = RBD53iG-5HacD2HnD
/caps-man channel
add band=2ghz-b/g/n name=2,4ghz
add admin-mac=******* auto-mac=no comment=defconf name=LAN
/interface wireless
# managed by CAPsMAN
# channel: 2437/20-eC/gn(17dBm), SSID: ******, CAPsMAN forwarding
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
MikroTik-**** wireless-protocol=802.11
# channel: 5320/20-eeeC/ac/DP(14dBm), SSID: *******, CAPsMAN forwarding
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX distance=indoors frequency=auto installation=indoor \
mode=ap-bridge ssid=MikroTik-**** wireless-protocol=802.11
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 keepalive-timeout=\
disabled name=pppoe-out1 use-peer-dns=yes user=********
/caps-man datapath
add bridge=LAN client-to-client-forwarding=no local-forwarding=no name=\
datapath1
/caps-man configuration
add country=romania datapath=datapath1 distance=indoors installation=indoor \
mode=ap name=*****_cfg security.authentication-types=wpa2-psk \
.encryption=aes-ccm ssid=******
add channel=2,4ghz country=romania datapath=datapath1 distance=indoors \
installation=indoor name=******_cfg security.authentication-types=\
wpa2-psk .encryption=aes-ccm ssid=********
add comment=defconf name=WAN
add comment=defconf name=LAN_NEW
add exclude=dynamic name=discover
add name=mactel
add name=mac-winbox
add name=LAN ranges=192.168.2.110-192.168.2.210
add address-pool=LAN interface=LAN lease-time=10m name=DHCPonLAN
/system logging action
add name=failedauth target=memory
/caps-man manager
set enabled=yes package-path=/ upgrade-policy=suggest-same-version
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=******_cfg \
slave-configurations=********_cfg
add bridge=LAN comment=defconf interface=ether2
add bridge=LAN comment=defconf interface=ether3
add bridge=LAN comment=defconf interface=ether4
add bridge=LAN comment=defconf interface=ether5
add bridge=LAN comment=defconf interface=wlan1
add bridge=LAN comment=defconf interface=wlan2
set discover-interface-list=LAN_NEW
add comment=defconf interface=LAN list=LAN_NEW
add interface=ether2 list=discover
add interface=ether3 list=discover
add interface=ether4 list=discover
add interface=ether5 list=discover
add interface=pppoe-out1 list=discover
add interface=LAN list=discover
add interface=ether2 list=mac-winbox
/interface wireless cap
set caps-man-addresses=127.0.0.1 enabled=yes interfaces=wlan1,wlan2
add address=192.168.88.1/24 comment=defconf interface=LAN network=\
192.168.88.0
add address=192.168.2.1/24 comment=defconf interface=LAN network=192.168.2.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.2.141 comment=LGwebOSTV_WiFi mac-address=\
******** server=DHCPonLAN
add address=192.168.2.0/24 comment=defconf gateway=192.168.2.1 netmask=24
192.168.88.1
set allow-remote-requests=yes
/ip dns static
/ip firewall address-list
add address=********* list=MyWAnIP
established,related,untracked
invalid
in-interface-list=!LAN_NEW
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=fasttrack-connection chain=forward comment="FastTrack DNS TCP" \
dst-port=53 hw-offload=yes protocol=tcp
add action=fasttrack-connection chain=forward comment="FastTrack DNS UDP" \
dst-port=53 hw-offload=yes protocol=udp
add action=masquerade chain=srcnat comment="Harpin NAT" dst-address=\
192.168.2.0/24 src-address=192.168.2.0/24
out-interface=pppoe-out1
add action=dst-nat chain=dstnat dst-port=37775 in-interface=pppoe-out1 \
protocol=tcp to-addresses=192.168.2.*** to-ports=37775
add action=dst-nat chain=dstnat disabled=yes dst-port=1194 in-interface=\
pppoe-out1 protocol=tcp to-addresses=192.168.2.*** to-ports=1194
add action=dst-nat chain=dstnat disabled=yes dst-port=443 in-interface=\
pppoe-out1 protocol=tcp to-addresses=192.168.2.*** to-ports=443
add action=dst-nat chain=dstnat comment=\
"****** access from: https://*******/" \
dst-address-list=MyWAnIP dst-port=443 protocol=tcp to-addresses=\
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.2.0/24
set ssh address=192.168.2.0/24 port=2200
set api disabled=yes
set winbox address=192.168.2.0/24
set api-ssl disabled=yes
/ip socks
set enabled=yes port=4713
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN_NEW
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN_NEW
/system clock
set time-zone-name=Europe/Bucharest
/system logging
add action=failedauth topics=critical,system,error
/system note
set show-at-login=no
/tool mac-server
set allowed-interface-list=mactel
/tool mac-server mac-winbox
set allowed-interface-list=mac-winbox
